Question about Maytag MGR5765QDQ CleanDesign Gas Kitchen Range
All four burners don't spark no clicking from start could it be a fuse
  • 5,911 Answers
The surface igniters are controlled by a single spark module. If your model number is correct the module lists for about $18 at appliancepartspros.com. Just type in your model number and look for item 11 (part number AP4098758) under the "Gas Controls" heading. If the model number is not correct, and you still need assistance, please post back and let me know. I hope this helps you.
Posted on Jun 25, 2009
The stove part has five burners, 4 outer and one in the middle. One day the four outer burners stopped lighting, but the center one still does light. The four outer burners all still click when...
Look for obstructions or a buildup on the spark tip on each burner. I use a tooth pick to clean around them. Let the burner completely dry before trying to light it since water will give a shorter path to ground which will produce a smaller on no spark at the burner.
Jan 03, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
I have a gas stove top but today all four spark igniters started sparking all at once an now won't turn off even when all knobs are in the off position
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 14, 2011 | Kitchen Ranges
All four burners of the stove spark without turning on the burners.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
heatman101
Jan 15, 2011 | Microwave Ovens
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR5765QDQ CleanDesign Gas Kitchen Range Logo
104 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
