Question about Intermatic T103R 120-Volt 40-amp Timer Switch-Double Pole / Single Throw
The yellow dial on my T103-70 does not operate. I can turn it on manually but it will not turn. Help?
    Problem Solver:
  • 8 Answers
The motor for the timer is shot you will have to replace the unit .Sorry
Posted on Jun 25, 2009
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Pride Celebrity scooter speed control dial
You can download the service manual from Pride's website. It has the wiring diagram in it.
Mar 11, 2013 | Pride Health & Beauty
Which is the on position?
You posted under Woods 59382
Open following link to identify timer for sure and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
To check switch setting and segment settings, plug timer into outlet, turn lamp on, plug lamp into timer, then manually rotate timer dial clockwise to check operation.
Change the switch, and rotate dial again to see when lamp turns on-off.
After segments and switch are set how you want, then rotate dial until current time lines up with arrowhead located on inner dial.
Analog timers like 59382 have small motor that rotates clock dial just like old fashioned clock.
As dial rotates, segments on dial move lever that opens and closes circuit to lamp.
The switch, or override button, lets you choose if you want timer program to operate, or if you want lamp ON all the time.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 16, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
of NO watering. The skipper wheel must have all pins UP for daily
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Timer will run when flipped on manually
THE YELLOW DIAL MOVES THE HAND STAYS IN THE SAME SPOT POINTED DOWN AND NEVER MOVES, THESE ARE A TUFF TIMER AND TO SET IT YOU MUST LIFT OUT ON THE YELLOW DIAL TO SET THE TIME AND THE DIAL SHOULD SPRING BACK TO THE GEAR TO RUN , MAKE SURE THE DIAL IS SET IN THE GEAR BY TURNING LIGHTLY LEFT AND RIGHT . LOOK ON THE BACK OF THE TIMER MOTOR AND MAKE SURE IT THE 208 - 277 VOLT . IF THATS THE VOLTAGE YOU ARE NEEDING FOR YOUR PUMP ONE MORE THING MAKE SURE THE GEAR FROM THE MOTOR IS MESHING WITH THE BIG GEAR THAT RUNS THE TIMER, THESE TIMERS GET RETURNED TO THE STORE WITH A BAD MOTOR IN THEM AND THEY JUST STICK THEM BACK ON THE SHELF.. IF YOU NEED A NEW TESTED ON I FOUND THEM HERE..YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT ..Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Jan 09, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Intermatic T103R 120-Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
295 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
