Question about Ricoh FT5832 Copier
Copier Failure Konica
Getting a Service code of 92-02 on a Konica 7155. Jamming in ADU.
Any clue??
Thanks, Dave
  • 1 more comment
  • Anonymous Mar 20, 2014
    konica 7155 code sc28-03
    how to adjust sepration leack
    error code SC46-01. does not pickup paper
  • 97 Answers
Note: For safety used please turn off the machine first.
- Check and clean all sensor if there are no obvious paper pieces stuck or dusty.
- Check and clean the Roller if you see dusty.
Posted on Sep 23, 2008
    Problem Solver:
  • 4 Answers
If there are no obvious paper pieces stuck, you could have either a problem with the dirty or worn rollers in the ADU, a dirty or defective sensor, or most likely a clutch problem in the ADU. Likely will require a service tech on site to repair to no obvious defects are seen.
Posted on Feb 26, 2008
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
Apr 21, 2013 | Konica Minolta 1312 Black Toner Cartridge
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Mar 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
We have a Konica Minolta Di2010 - we are getting a message on the screen that read: "A malfunction was detected. Please call your tech rep with this code: C0920" What can I do to get the...
C0920 as per the Minolta Factory Service manual is caused by a tray 1 lift motor failure. In my experience with this code, it is usually caused by paper loading in the tray or something jamming the tray. Best solution is to remove all paper from the tray. Leave the tray open an inch or 2 and turn the main power switch off then back on. The main power is on the back of the machine NOT the one on the right edge of the operation panel. Once the code has been cleared then try a test copy by using one of the remaining trays. If it works correctly then re supply paper into the top tray 1 and then see if the code returns. If it does then either your lift motor is bad or you have something jamming up the lift plate in the paper tray. You can always leave that tray open and run the machine until you can get someone out to look at it. Most of the time tho, reloading the paper in the tray will solve the code.
Good Luck and Thank You for using Fixya
Dec 16, 2010 | Konica Minolta Office Equipment & Supplies
To Blade Flip: RE: F-28-3 Error on a Konica 7020
when you open number 6 there is a corona unit in there(t/s unit) and on the adu outer door there is the casing unit, has 2 springs in it, wheh you take this off and split it the sleeves inside will be powdery.
very simple to fit these items, not that costly either. It would be cost effective to buy the whole of number6 with the t/s unit in it.
Jun 27, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Konica di3510 there is a code on the screen cobao
Elevation drive motor failure for the finisher /service manual
May 05, 2009 | Konica Minolta DiALTA Di200 Copier
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
Ricoh FT5832 Copier Logo
138 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
