Question about Samsung BlackJack II Smartphone
Mic volume almost nothing
I have a similar problem but even one step further. For some reason the mic on my BJ2 turned down to almost nothing. I could hear other callers fine but they could hardly hear me-- like I was in the bottom of a tin can. I got a bluetooth earbud and that helped side-step the problem for about a week-- but just today I was in the middle of a phone call and my phone did the exact same thing. The person on the other line couldn't hear me very well. Now, bluetooth or not, my phone doesn't pickup my voice.
Anyone have similar issues? Any solutions?
I have Corby pop GT-C3510. No one hears me.
Posted on May 03, 2010
  • dixitsandeep May 03, 2010
    I have Samsung corby GT-C3510
I get ALOT of feed back, why? I can't use it like that. I've talk with the a Tech and he said I needed to stand further away from the amp, which I am.
This sounds like your gain is too high. Adjust it down. Every mic has different gain settings so you can't just blanket this with the other one works fine. Is this wired or wireless?
Dec 24, 2014 | Shure SM58 Professional Microphone
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
When I set the effects to the channel for the mic, It kills mic volume
Check your mic input settings, click the "VOLUME" control (and/or sounds fron control panel)... also check and PLAY with "GAIN +20" on the settings..
Write me back on your results..and tell me your OS... question was vague..hope it helped.
Oct 18, 2012 | Tascam DP-02 8-Track Digital Recorder
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Micophone problem
Microphone might be in mute mode or the volume of the microphone is very low. I assume that you have inserted the jack of the Microphone in the correct port colored pink.
In Windows XP :-
Step 1. Click Start -> Control Panel -> Sounds and Audio Devices
this will open a window
Step 2. Click on the Volume tab and under Device Volume click on
Advanced tab will open the Master Volume window
Step 3. Search for the Mic Volume, if it is not there click Options ->
Properties and then check the box beside Mic Volume under
the volume controls then click OK now it will show in the
Master Volume
window.
Step 4. Then check the volume of the Mic Volume is full and there is
no check mark beside Mute.
If this doesn't solve the issue give me a feedback about the problem with much more details and the operating system you are using.
Jul 07, 2010 | Intel D845GVSR Motherboard
Suddenly MIC port is not working...
go to volume control option and select mic advace option and choose microphone boost option and try.
Jan 20, 2010 | Gigabyte GA-K8VM800M Motherboard
Is there anyway that I can turn the microphone off on my camera. I don't need the sound. The camera is used for work.
I don't think you can actually switch off the microphone, but turning the recording volume all the way down should do the trick.
Nov 30, 2009 | Canon ZR800 Mini DV Digital Camcorder
Mic not working stilllll!
I'm not certain about yours, but my Acer Aspire 5920 has an audio/volume turn button, just under the lip of the laptop, just to the right of center. Even if you un-mute it, if the volume is turned down all the way - the button revolves, so looking a the front, turning it counter-clockwise will turn the volume down to off, and you won't hear a thing, no matter how much you try to un-mute the thing.
So turn that rotating button to the right, to make it louder, after you have un-muted a control panel volume slider and moved it up, and that just might make it work for you.
Jun 25, 2009 | Acer Aspire One PC Notebook
Microphone not picking up the voice
In order to use another microphone other than the built in microphone on a Logitech web camera, you will need to configure the new microphone to be your system's default microphone.
To change the default microphone in Windows:
  1. Click "Start," "Settings," and "Control Panel."
  2. Open the applet that corresponds to your operating system.
    1. Windows 98 users, double click on "Multimedia."
    2. Windows Me and Windows 2000 users, double click on "Sounds and Multimedia."
    3. Windows XP users, double click on "Sound and Audio Devices"
  3. Click the Audio tab.
  4. Set the microphone to the sound card in the drop down box that is appropriate for your operating system.
    1. Windows 98 and Me users, click on the Preferred Device for Recording box.
    2. Windows XP and Windows 2000, click on the Default Device box under Sound Recording.
If you are using the built in mic, open the Quickcam 11.5 software and adjust Audio Settings.
The Audio Settings provide access to device selection, basic audio levels, and AEC.
  • Select Microphone– Allows you to select desired microphone for video calling and video recording applications.
  • Volume indicator – Indicates the current input volume level..
  • Adjust Recording Volume – Toggles input volume level.
  • Cancel Echo – Enables or disables AEC for RightLight and RightLight 2 supported cameras.
  • Select Speakers – Allows you to select desired speaker source for video calling and recording applications.
  • Audio Tuning Wizard – Launches the Audio Tuning Wizard
If all this fails, it could indicate a problem with your soundcard. Try using some speakers or another mic and see if they work. If they don't, you card is faulty. Remenber to set up your mic in the volume properties. On the lower right hand of the screen, you should see a volume icon. Right click and select open volume control. Select Options and the Properties. Select Recording and check all boxes below. Close that window and now make sure Mic level is max and not muted.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 04, 2008 | Logitech QuickCam Pro 5000 Webcam
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
Samsung BlackJack II Smartphone Logo
232 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
