Sport & Outdoor - Others Logo
Posted on Jun 25, 2009
How much sand does it take for a BaquaPure 22 gal. tank?
Also what specific type of sand does it use?
  • Anonymous May 11, 2010
    more info please
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 26, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
3422
Points
19
If the tank is 22" you use 100 lb. 24" 150 lb 26" 200 lb.
50/50 silica sand works best.
1helpful
New Pancake, 6-gal., sand inside, what should I do to get it out of the tank? Could the sand be from the manufacturer using sand to cool the metal after manufacture?
All air compressors have a water drain device on the bottom of the tank.
Get a wrench and remove this part. Shake all the sand out and maybe shoot some air up n there if you have canned air or another compressor to use.
Wrap the part with new teflon tape and reinstall it.
2answers
Our pool is about 90000 litres of water so how big filter do we need please
If you have a above ground pool go with the Cartridge or sand, and if underground go sand or D.E. All have their ups and down you should find out what you want from them specifically cause they all do varying amounts of the same thing.
Sand Filters
(Filters using literally sand)
For sand filters, on inground pools, I like to use a 30 inch tank diameter, which is a 4.9 sq. ft. filter surface area, and holds 600 lbs of sand. For small pools (under 20,000 gals), I might advise the next size down (24 inch tank), if the budget is tight. But never go smaller than a this for an inground pool.
Cartridge Filters (like a air filter)
I have a rule of thumb for cartridge pool filters. 100 sq. ft. of filter surface area per 10,000 gals of pool water, as a minimum. I like to see the 400 sq. ft. models on inground pools above 25,000 gals. These can go an entire season without cleaning in most cases.
D.E. Filters (Ground up fossilized algae)
Because they offer the most superior type of filtration, people tend to go small with DE, and buy a 24 or 36 sq. ft. DE filter. Ugh - go Big! Nothing below a 48 sq. ft. filter, and if your pool is over 25,000 gals, go with the Big Boy - the 60 sq. ft. filter.
Swimming Pool Blog
Also make sure the filter can take the amount of water that the pump is pushing through it.
Jul 23, 2015 • Pool & Spa
Hayward pro series 22" A professional installed
for starters, a 22" filter should have been filled with roughly 300lbs of sand. this information will be found on the filter body and in the owners manual.
Sep 25, 2014 • Pool & Spa
We need information on the weel base of Fuel Tank Envoy /Trailblaizer 2004.
Fuel tank capacity for the standard wheel base Envoy/TB is 22 gal. and 25.5 gal. for the extended wheel base model.
2helpful
2answers
It has two gas tanks and I need to know the volume, in gallons, of each?
The rear tank is rated 22 gallons, the side tank is rated 19.5 gallons (actual usable capacities are about 1/2 gallon less than posted capacity).
Please rate my help, thanks
How many literes does it take to fill my envoy from empty
If you have the standard wheelbase Envoy, you have an 18.7 US Gal. tank, if you have the XL model, it has a 22 US Gal. tank. Don't know off hand the conversion to liters.
2answers
After filling my fuel tank, gauge does not go to full....it takes a few days or hours for gauge to read full
There is a TSB on high sulfur fuel usage, and how it impacts the fuel level resistance.
If you change fuel, it might start working again. The TSB is : ERRATIC FUEL GAUGE OPERATION TSB 08-2-9
Publication Date: January 22, 2008
FORD: 2004-2008 F-150
LINCOLN: 2006-2008 Mark LT
ISSUE:
Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulfur contamination in the fuel causing an open or high resistance in the fuel level sender.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit.
PART NUMBER PART NAME
8L3Z-9A213-E Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-26 Gal Tank - 126/132" WB )
8L3Z-9A213-F Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-30 Gal Tank - 139" WB)
8L3Z-9A213-G Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-H Kit - Fuel Sender (2006 starting 12/8/2005 through 2008 - FFV-36 Gal Tank - 145/151/163" WB
8L3Z-9A213-A Kit - Fuel Sender (2004 through 2008 - Gas-26 Gal Tank - 126/132" WB
8L3Z-9A213-B Kit - Fuel Sender (2004 through 2008 - Gas-30 Gal Tank - 139" WB
8L3Z-9A213-C Kit - Fuel Sender (2004 through 2008 - Gas-27 Gal Tank - 145/151/163" WB
8L3Z-9A213-D Kit - Fuel Sender (2004 through 2008 - Gas-36 Gal Tank - 145/151/163"WB
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080209A 2004-2008 F-150, 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9A299 42
3helpful
3answers
How big is my gas tank on my 1989 dodge 150 full size truck
Should be 30 U.S. gal (25 imp gal; 110 L)as you have the higher end model. The lower end models have 22 U.S. gal (18 imp gal; 83 L)
3answers
Fuel tank capasity
it should be 18- 22 gallons depending on engine size and awd
4helpful
I have a baquapure sand filter please help
if leak is around the top 7-way valve it is probably the rubber o-ring underneath that needs replacing. if the tank itself has a crack or hole you could try something like j/b weld to patch the hole.
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
