Question about Eddie Bauer PE702 Portable DVD Player
Blank Screen My Portable DVD Player has power but a blank screeen.
I don't know if you ever got an answer or not, but we have this same unit and also had this problem. (now we have a different problem) Anyway, there is a small button on the mail base that I think is on the upper right. When the screen is closed the button is compressed, when the screen is opened it should fully pop out, but ours did not. It appeared to be, but if you pressed it in, it would fully pop out and the screen would work. Sometimes we had to do this several times during a trip. For some reason it would not stay fully popped out? We had already taken the exact same DVD player back to Target because of this same problem, only to have the second unit do the same. I bought this particular player because I assumed with the "Eddie Bauer" name it would be quality. I was mistaken. Hope you already figured this out. Sincerely, T
Posted on Sep 23, 2008
Dvd player will not read disc and screen do not turn on
1. Bad servo motor or 2 bad optical laser would be the two things i would Rule out before trying anything further.
Sep 23, 2009 | kawasaki PVS1965 Portable DVD Player
Battery not charging screen blank n when power on
check the connectivity of the charger using a multimeter. if there is anything wrong in it, you might have to open up and replace the wire in the charger. if the connectivity in the charger has no problem, then try replacing your batteries
May 28, 2009 | Koss KS4110 DVD Player
The screen is blank and white and the sound works
maybe the set-up of your dvd is pal. try to select auto
May 05, 2009 | Televison & Video
Portable dvd player, Screen is blank
Check the video connectors, make sure the pins are not bent.
Mar 17, 2009 | Audiovox D1888PK Portable DVD Player
Troble shooting:[D1500B] When the player gets heated up, the scrren goes blank and the player stops.
Your adaptor may be giving out more voltage than required by the player.First,change the adaptor,if the problem still occurs that means that the power section of the player is weak.
Jan 06, 2009 | Audiovox D1500B Portable DVD Player with...
Nextbase SDV1102-B has black screeen.
I have also one liket that and had the same problem.
The connector is moving and the screen changing from black to white but sometimes nothing. I've managed to have the screen back normal but only for a moment.
Now it is dead again.
I'm sure it is he connector to the screen which is very sensitive.
Dec 12, 2008 | NextBase SDV-17 Portable DVD Player
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
DVD not working
When I turn on the DVD player the light comes on buts thats it. Just blank screen, and no sound anything whatsoever.
Dec 12, 2006 | Philips MPD720 Portable DVD Player with...
Blank Screen
The screen in your dvd might not be getting the volts it needs to work,the ribbon cable that comes from the base gets broken sometimes because of the hinge action of open and closing constanly.You need to call RCA at 877-794-7977 and ask for an estimate or an idea of how could cost to repair.Good luck.
Oct 17, 2006 | RCA DRC16N Portable DVD Player with Screen
Eddie Bauer PE702 Portable DVD Player Logo
140 people viewed this question
Top Eddie Bauer Televison & Video Experts
Are you an Eddie Bauer Televison and Video Expert? Answer questions, earn points and help others
