Question about Toshiba 42HM66 42" Projection HDTV
TV WON'T TURN ON (TOSHIBA 42'' LCD) - Toshiba 42HM66 42" Projection HDTV
5 Suggested Answers
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
  • 8457 Answers
SOURCE: 42" Toshiba Plasma TV wonn't turn on
Power board require changing.It dead.
Posted on Jan 08, 2010
windowvistab
  • 139 Answers
SOURCE: Hello, I have an Toshiba REGZA 42" LCD TV, the
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will help in solving the problem.......
Posted on Jun 16, 2011
SOURCE: my toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Posted on Aug 03, 2012
Won t turn on
What model is it ? Explain "Won t turn on ".
Aug 31, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
TV worked 1 day and no sign of power when turned on the next.Toshiba REGZA 42
if no any power indicator at the front panel, check for a blown fuse at the power supply board.
Oct 27, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba 42HP66 42 in. LCD Television Color Problem
se cablesdry joints or loooossibly the ribbon cables check for
Sep 19, 2012 | Toshiba 42HP66 42 in. LCD Television
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
Toshiba Television will no turn on, timer record lite flashes when trying to tur on T.V
Sep 05, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Programing my toshiba remote
go here:
http://www.tacp.toshiba.com/televisions/lcd/large.asp
select your tv and then click on resources and then open up the manual for your tv.
Dec 08, 2008 | Toshiba 42HL167 42 in. LCD Television
Toshiba 42HM66 42" Projection HDTV Logo
543 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
