Question about Tomtom One Europe v2 GPS Receiver
Tom Tom SD card
What size sd card should I use for my tomtom xl one gps.
    Problem Solver:
  • 9 Answers
Hi, only the ones supplied by tomtom
Posted on Jun 26, 2009
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
My tomtom 1 xl is giving me a memory card symbol on the screen with a red cross over it !
do you have an sd card loaded?
if so and it hasnt been formatted for the tom tom then this can cause your issue, also if there has been an sd card in the device and then removed unexpectedly you will get the same issue.
hopefully this answers your query if so please rate my answer accordingly.
Thanks
Sep 14, 2009 | Tomtom One XL GPS Receiver
I tried to put an SD card in my tomtom ONE XL and now it won't do anything...it is flashing what looks like a hard drive and there is a red X over the picture of a hand.
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
then just copy ALL the files from the tom tom to your sd card
It should now work
Aug 26, 2009 | Tomtom One XL GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
After updatetd from tom tom home does not work anymore
you are using the tomtom update application on PC?
your download is complete? New charts and firmware?
Make sure you download right firmware.
If not download right one.
Besure map download wasnot broken off because of time-out.
Format after backup your SD card. Start reinstalling firmware and then maps. Be sure not too have too small memory size SD card.
I have been in this mess. TY TomTom for your bad service
Apr 15, 2009 | Tomtom ONE XL GPS
Tom tom one xl memory key
It's a standard SD card that you can get from electronics or camera shops. 1Gb should be OK.
Peter
Mar 05, 2009 | Tomtom One XL GPS Receiver
Tom tom Western european map
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
Feb 24, 2009 | Tomtom One XL GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
219 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
