Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon Pixma ip1500 feeds only on right side
Tried the cleaning features (roller and bottom plate) and tried using a dab of alcohol on a lint free cloth, but paper still won't feed properly.
    Sergeant:
    Champion:
  • 253 Answers
U need to get your roller cheked and contact your dealer
Posted on Jun 25, 2009
Canon pixma MP145 pulls two papers in one time
Where the paper feeds, the pick up roller and separation pad are likely fouled with paper dust or other particles. They may be wiped with a lint-free item, moistened with clean water. Do not get the surfaces wet, do not use isopropyl alcohol, do not use detergent or cleanser.
Oct 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP140 all in one inkjet printer - paper won't feed through machine. Pulls from right and jams instantly. Tried roller cleaning but last step is to feed 3 sheets of paper through and it does the...
One of the feed rollers -probably the one on the left- is slipping. Clean it with a soft cloth dampened with alcohol. While you're at it, clean all the feed rollers.
Jan 29, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma iP1500: How to insert 5 springs on internal plate?
I just lined up the main housing, put the 2 screws in the front (did not screw in the 3 side screws) ( tried it when the housing was off the springs would just fall down)
just slide the springs in after it is screwed in the short side fits into the white plastic you will see grooves where it lines up on the white plastic piece, the long side of the spring hooks on to the back metal hook on the other side the coil rests in the middle of the prongs
http://i945.photobucket.com/albums/ad294/seichal/ip1500%20springs/20150210_183120_zps7e85807d.jpg?t=1423531107?143
May 04, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
Feb 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Loading Paper Error Pixma MP170
Your feed rollers are either dirty or worn at some point. Try cleaning them with alcohol on a lint free cloth. Make sure you clean the entire circumference of the roller, or at least half of it.
Feb 03, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon Pixma iP1500 printer indicates paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
140 people viewed this question
old marine
old marine
