Question about LG WM-2277HW Front Load Washer
Is there a fuse on the LG that can go out or be reset. I am getting no power to the panel?
  • 3 Answers
No resetable fuse , trace voltage from power cord to board ,there is a small filter board that sometimes goes.
Posted on Jun 26, 2009
My lg wm1814cw won't come on but outlet have power
Possible that the power supply to the program controller unit has failed or that the program controller panel by itself has failed.
Remove the panel after disconnection of power and check for input power to the panel, check for fuse., if the fuse blows up again the board can have shorts within and will need a replacement.
Jan 15, 2013 | Washing Machines
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
TV will not power on. Check supply to set and it is fine. Tried remote and local power switch. Is there an internal reset? The unit is a LG 37 inch LCD approx. 1.5 years old.
There is not an internal reset for this. You would need to check what voltages you are getting from the secondary side of the power supply, this would then indicate if the problem is with the main board not starting up the system or if the power supply has a fault. If you have a multimeter then you can carefully check for 24v 5v & 12v supplies. If you are not getting any voltages then the primary side of the power supply may be at fault. The first thing to check would be the fuse at the incoming mains supply on the power board, if this has blown then suspect one of the senmi-conductors & check to see if any of the capacitors are swoolen if so replace them.
Dec 07, 2009 | LG 37LG50 37 in. LCD HDTV
Blown Fuse LG LCD
Unplug tv and let it set for a couple of hours. Remove the back panel, the fuse is located somewhere near where the power chord comes in. Remove fuse and replace with one of the same rating.
Nov 12, 2009 | LG 32LP1DC 32 in. HDTV LCD
TV TURNS IT SELF OFF AND ON I HAVE A LG 42'' MODEL 42PC3DV
hi,
you need to replace it.I think it is 4AH250V. You can buy it from any electronics shop near u or u can get it from ebay.com
Thanks!
Sandy
May 22, 2009 | LG 42LC2D 42 in. LCD HDTV
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
Radio Not Working
There are 3 fuses in the interior fuse panel that feeds radio.
no. 11(10amp) is ignition switch power to the radio it comes into radio on the TN/LB wire.
no. 27 (10amp) is hot at all times and comes in on OG/LG wire.
no. 12 (5amp) is hot in run or accessory and comes in on YE/BK wire.
Check these with 12V test light at fuse and at radio connector.
Mar 11, 2009 | 2001 Ford Escape
LG WM-2277HW Front Load Washer Logo
651 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
