Question about Dometic Refrigerators
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners by decorative plastic strips which run the widt of the door at the top and bottom. On this door, both of these strips are cracked and broken in the corner of the hinge pin area. Also, the small round plastic bushings, flat on one end, which fit around the hinge pins are worn and broken.
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Posted on Nov 28, 2010
How do i change the door so it opens from the right
Check the top and bottom of your fridge door at the furthest edge from the hinge. Do you see a plastic plug/insert, usually round that looks like they can be levered out with a thin blade? These cover holes that a hinge pin can be inserted into. At the hinge side (top and bottom in the same position as the aforementioned plug/insert) is where the hinge is attached to the door. If you remove the hinges from the fridge they should then come away from the door and you can swap them over to the other side and replace the plug/insert in the holes left where the hinge pins were originally fitted. The door should then be fitted to the other side of the fridge in holes similarly covered by a cap that you put in the holes left where the hinge was fixed.
I hope that makes sense, because I've just read it and confused myself I think.. ;)
Nov 20, 2015 | Refrigerators
Why is door still open at top after replacing door hinges on Whirlpool WFE510S0AW0
Well, I assume you have the door hinge clips in the right position,
and the door is seated properly with that 2mm slot that sits on the hinge receivers. If hinges are replaced, then it must be hinge receivers.If the door is crooked, moving the hinge receiver will align the door. Besides hinge receivers should be replaced first, before the hinges, that in my experience rarely break
I dont like the bent twisted story. I bet the little plastic U-roller in the hinge receiver is worn down or cracked. Fix is to replace the hinge receiver (a secondhand one is in plentiful supply) - or find a look alike roller and fit it. Cord pully's at the local hardware store may fit, window slider tracks, or even coins with a small 1 inch by 4mm bolt as an axle will do the trick.
Still not sure. Remove the dorr using instructions, and set aside.
Remove hinge receivers from each side. Are the little wheels in there good, or wobly, worn of missing?
Problem Fixed
May 22, 2014 | Whirlpool RF378LXKS Electric Kitchen Range
Replacing hinge cam pin
I may need a picture to determine what is wrong. there is a screw-in pin that has a flat head top that you screw in. If that is in place, but the little cam itself (it's chrome with a black plastic center) is getting past the pin, then you have other problems. Either the 2 white plastic door closer cams on the bottom hinge are broken/worn/missing, or the lower hinge is sagging where it attaches to the cabinet of the unit and that needs to be replaced. These things can allow that cam to pass the 90 degree stop pin even when it is in place. you can look at a diagram of the hinge at http://www.greatplainsapplianceparts.com/order/subzeroparts.asp? (the question mark should be part of that link, but it won't take it so you may have to add it in the browser after you click the link). Let me know if this doesn't solve your issue!
Jan 14, 2014 | Sub-Zero 611 / O Bottom Freezer...
Door lock keypad anchor
You have to order the part from a dealer. The issue might not be the sleeve though if you check the bushings at the hinges, they are probably worn. You can get door hinge bushings from an autoparts store. Then you drive out the hinge pins and bushings and put in new ones. What happens is over time, the bushings where and then the weight of the door causes the latch to strick the retaining anchor.
Aug 31, 2013 | 1996 Ford Explorer
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Lower oven door won't close. Hinges were replaced by Sears but didn't help. Problem is internal. How to get at it? How to remove oven from wall?
On the lower right side of this link is a picture of various major parts of your ve in a exploded diagram. The door and oven assembly is one of them. You can look at the diagrams and see how your unit comes apart.
http://www.ronhazelton.com/archives/howto/oven_replacement.shtm
Let us know if you need further clarification.
Thanks for contacting fixya.com
Dec 26, 2009 | Kitchen Ranges
Best way to removed driver side door
I have a 1994 Grand Caravan and have done this several times.
1. Disconnect Negative side of Battery.
2. Remove all screws.
a. There are screw covers to remove first before
gaining access to the screws. I use a pick
driver.
b. One in recess of the door arm rest. Round
Cover.
c. One is behind the door latch release. Pull/Hold
open to gain access. Then remove the cover
d. Two are located on the Map pocket. Round
Covers.
e. One is located up near the side mirror.
f. One is located on the upper portion on the door
handle. It has a square cover.
3. Pry up and out the window/mirror adjustment cover and unplug the connection.
4. Use a wide flat screw driver to carefully pry on the bottom then side edges of the trim panel to "pop" the retainers out of the door.
5. Once all retainers have been freed: Lift up the door trim up off the upper ledge.
6. Peel back (but do not entirely remove) the rubber/plastic watershield cover.
7. Disconnect all wire connections to the door trim.
8. Pry off the plastic retaining clip to the door handle metal bar and remove the "L" bar out of the plastic connector.
9. Set the Trim Panel off to the side.
10. Remove all wire holders from the door.
11. Move the wires inside and towards the front lower access hole.
12. Peel back the rubber wire guard between the door and the A-pillar frame.
13. Pull out as much wire as possible out of the door and let hang..
14. While someone else is supporting the door: (If no one can help: with the door fully open: use a jack and block of wood to support the bottom outer edge of the door
a. I use a Breaker Bar or long Wrench
Extention and Hammer or Mallet.
b. Tap Up the Bottom Hinge Pin first.
c. I also use a flat Screw to tap up the Pin Head.
d. Remove the Bottom Door Hinge Pin.
e. Remove the Upper Hinge Pin the same way.
f. Make sure the Door is being held in place.
15. Remove any left over wires out from the door.
16. Carefully move the door away from the hinges.
Good Luck!!
If you have not replaced the Hinge Pins, and Guides, now would be a good time to do it!!
Nov 14, 2009 | 1994 Dodge Caravan
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
Refrigerators Logo
391 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
