Question about Mitsubishi VS-60805 60" Rear Projection Television
I have a VS 60805 and i need a Convergence Generator. They say these are no longer Available. Any Suggestions?
General Consensus is that Mitsubishi is a Piece of ****, has been for a long time and I was lucky that my Set worked as long as it did. I guess it is just another benefit of not have any national product in the US anymore. No matter I will never Buy Mitsubishi Again.
Posted on Jun 26, 2009
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Convergence gets very bad the longer the TV is on.
The convergence amps will have number on them starting with STK replacing thes may do the trick or you may just have a poor solder connection at these ic's try soldering them first if no go then replace them look around on the convergence amp cba on the bottom for obviuos bad connections small ring crack are hard to see these ic's work hard that is one reason for their large heat sinks running the set and turning it on and off may have induced fine ring cracks. i amsorry I dont have a schmatic for this set but the ic's do have their (generic) part number wrote on them as do most all transistors and diodes and ic's
Aug 22, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
Can you help me please
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Please help super bowl depends on it
Sony Convergence
Convergence problem.
This denotes that the convergence amps are going bad or the biasing resistors are failing. Check the bias voltages on the amplifiers to determine if this is indeed the problem. If it is try to replace the biasing resistors first, then if this does not clear up the problem, replace the convergence amplifiers. Also check the convergence coils for problems.
I hope this helps,
Thank you,
Shuttle83
Jan 22, 2008 | Mitsubishi VS-60805 60" Rear Projection...
1080i connection has green hue
Sony Convergence
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
