Question about Kenwood KDC-7011
Will flip but does not light up or allow for and controling
  • 578 Answers
You need a new face plate those unit does that over time
Posted on Jun 25, 2009
How do I unlock the dishwasher? The lock light is blinking/steady.
Like many computer drive devices, a good place to try is the "power off reset" which in this case will mean you have to:
  • go to the circuit breaker box and locate the breaker for the dishwasher
  • flip the breaker for the dishwasher off.
  • Wait a short time (~30 seconds) and
  • flip it back on.
In many cases this simple power cycling allows the little computer inside to recover. This applies to any device with a computer/micro-controller inside.
Good luck.
Feb 18, 2016 | Dishwashers
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Jul 18, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to reset the alarm on freezer
Hello Friend, this is Z. Thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Jul 14, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door ajar light lit with door closed
Good Afternoon Don, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Oct 12, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridgedare front load dryer wont start, no noise, the light is on so i know it is getting power. finished one load went to start another and turned the switch and nothing
Hello ebega7 - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately ten minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
Jan 04, 2013 | Frigidaire FGQ332ES Gas Dryer
Crosley gas dryer panel lights blinking will not turn on
Hello - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
Oct 14, 2012 | Crosley CDG6000 Gas Dryer
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Lost time on flip ultra video camera,was 2 hr, now 1:45
The Flip has a hidden file folder where it stores files that might not have been properly removed. To clear these off the Flip. Use the control panel on your PC to allow access to hidden folders and hidden files. Once this is enabled, search the Flip for a folder called "trashes". Emptying this folder will clear the memory and return the Flip to it's full time.
Feb 27, 2011 | Pure Digital Flip Video Ultra Camcorder
The power button on my 360 puts the one green light on the right instead of the left
I have a very similar problem I had a few days ago. But what I did was I shut down the Xbox 360 console completely. Then I unplugged the power cord from the Xbox 360 console and the wall outlet, and then I disconnected the batteries from the wireless controller. let it sit for about 5 min. Then plugged everything back in, and finally I hit the the wireless connecting buttons on both the Xbox 360 console itself, and the wireless controller(s).
And from then on, I have had no problems, what so ever since I did that (above).
Jan 05, 2008 | Microsoft Xbox 360 Console
Controls
The connector is probably dirty. Open the case and remove the two screws on each side of the control ports. Pull the control port up and you will see where the ribbon cable connects. Flip the connectors hold up to release the ribbon. The connectors hold is the darker piece on top right where the ribbon enters. it flips up. Use your fingernail to get under it and flip it up.
Now that you have the control port out. You can wash and clean the fool out of it. Allow it to dry real good before hooking it back up. This may get your control port working again. While your in there clean up other stuff.
Nov 11, 2007 | Sony PlayStation 2 (PS2) Console
Kenwood KDC-7011 Logo
90 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
