Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
18hp B&S wont slow down no matter where
18hp Briggs intek wont slow down no matter where throttle is set
  • Anonymous Mar 15, 2014
    Engine backfires at random and when throttle is ********
  • Anonymous Mar 23, 2014
    won't idle down runs at 3000rpm no matter where throttle is set
  • 376 Answers
It's one of two things. Most likely, the screw(s) have come out of the butterfly valve on the throttle shaft and letting it run wide open. The second thing is that the governor gear inside the engine broke. Unless you a pretty good mechanic, I'd recommend taking it to a shop. If it is just the butterfly in the carb, you still have to deal with...where did the screws go? They may have passed through the intake and exhaust valves or they may be stuck in one of the valve seats or embedded in the piston. Like I said, better take it to a trusted shop, if there is such a thing, unless you live close to me. lol.
Posted on Jun 25, 2009
  • 80 Answers
Sounds like the butterfly on throttle shaft has broken loose or the shaft has broken I have repaired several of these and it seems to be a common problem. Be sure to check for all the parts as they could be loose in the cylinder or stuck in the intake
Posted on May 29, 2013
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My intek 18hp will only run with choke fully closed.please advise possible problem &solution .the throttle seems to have little impact on the running of the engine
Hi and welcome to FixYa. It sounds like the metering jet in the bottom of the carb throat is clogged.
1st turn off the fuel supply
You will have to remove the float bowl from the carb and then the BRASS jet / orifice. Once removed hold it up to the light.. you should see a pinhole of light thru the jet. No pin-hile = run only with choke. ALSO the nut / bolt that holds on the float bowl has 2 holes in it make sure those are clear.
Before you reinstall the float bowl turn on the fuel and catch it in a spray paint can lid or something similar. It should flow rapidly and stop as you GENTLY raise the float. If no flow then you have a stuck needle and seat or a clogged fuel supply line. Correct same and reinstall the filter bowl. It should run fine after that.
Thanks for using FixYa!
Kelly
Mar 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & stratton 18 HP intek ohv won't start
check the safety switches one of them are bad
Jun 25, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
897 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
