I have a new LaCie hard drive, Sam Hecht, 500 MB, serial number 1296903293115G. I am using a Mac OS X 10.5.6. My problem: The instructions say that when you want to disconnect the drive, you drag Mackintosh HD icon to the trash. Then it's safe to disconnect the LaCie. However, the HD icon does not disappear. (I can't believe it should!) My question: Is it then safe to disconnect the drive anyway? William Michael
This would mean it is somewhere (maybe by the OS) still in use. If you have any open files from the drive, close them and try again. If it still happens, its in use by the system. Technically its not "safe" to remove, but even if you do remove it now it is most likely nothing will go wrong, as is mostly the case.
If you want to be extra safe, simply restart the Mac, and it will dismount it safely upon restart.
Best regards
nLinked
Posted on Jun 25, 2009
Why does my new 500gb lacie setup say 375.7 MB, Zero free?
Hi Anon
I think this is the setup disk, your 500gb disk will have have hundreds of gigabytes of free space, remember that 375.7 MB is roughly a third of 1 gigabyte.
Aug 31, 2014 | LaCie Rugged Triple hard drive - 500 GB -...
LACie disks are mounted on the desktop
http://www.pricespider.com/products/454765/LaCie-D2-301110U.html
This link has product reviews and problems others have had with it. It may be worth checking out.
Let me know how it goes,
Thanks
yalmer
Mar 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have La Cie SAM HECHT and once i attach it to any PC/Laptop its not getting detected, I am not able to access the drive, Please suggest what I should do. Thanks and Regards
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
I have a LaCie Rugged Drive, with multiple interfaces (USB, Firewire 400/800). Firewire interface works fine. When I plug the drive in the USB port, it won't mount (MacBook Pro OS X), and a faint beeping...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie (300951U) 500 GB Hard Drive
Plus de lecture sur mon MAC
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur
Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la
fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails
de vous. Mais, au moins à vous diriger dans la bonne direction.
Tout d'abord voici le lien pour votre externe LaCie USB 2.0 500 Gig
Disque dur pour plus de soutien de LaCie:
Lien:
* LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Hard Drive Support
En outre, si, pour plus de soutien pour des problèmes avec ce disque dur, y compris si nécessaire d'avoir à reformater votre disque dur, voici le lien:
Plus de dépannage pour votre LaCie externe USB 2.0 500 Go HD pour Mac.
Si vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
Observe,
-Mactechtrainer
Jan 30, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Partitioning lacie hard disk 2.0 500 gb
Windows XP: Right-click on "My Computer" and select "Manage". From there, select "Disk Management" which lets you view the drives and do things to. More details here...
If you're on Mac OS: Here's how
Mar 20, 2009 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
My hard drive won't show up on the mac
Mac OS can not repair a non-native partition like NTFS and will not mount a drive with errors. Repair the drive on the native system and this should resolve the problem.
Dec 08, 2008 | LaCie (301065U) 500 GB USB 2.0 Hard Drive
LaCie HD won't show up on Mac desktop, quit showing up yesterday
Hello! Had the same problem - go onto the Lacie official website. Select whatever type of drive that it is you have, and simply go onto the software update page. I literally downloaded the desktop manager (I own the Sam Hecht Little Disk) and it appeared! Good luck
Nov 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Oct 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
