Question about GE Dishwashers
Model# PDW928ONOOSS The Hinge failed on right side facing it. It appears they press welded it? ANy suggestions?
4 Suggested Answers
  • 508 Answers
SOURCE: How to replace '96 Ford Explorer driver side exterior door handle
You will need to remove the door panel to gain access to the handle. Roll the window up or down as needed to get to the nuts that attach the handle to the door. You will also need to remove a rod the goes to the door lock. You will see the rod after the door panel is removed. Good luck.
Posted on Feb 18, 2009
  • 10865 Answers
SOURCE: Bottom right side door hinge
http://www.jennair.com/content.jsp?name=parts_stores go to this link and you can get the part u need
Posted on Apr 16, 2009
  • 15 Answers
SOURCE: 1 Solution for "I am out of warranty and the hinge is failing
If you are comfortable taking it apart, get a replacement on ebay.
Posted on May 10, 2009
This hinge has snapped in two Can it possible be welded back together again?
It depends on what material it is made from. The easy answer is yes most materials can be successfully welded but some materials are more problematic than others and need specialist equipment and skills.
If the material is mild steel you will have no trouble getting the welding done once the hinge has been removed from the door and the oven. I think that could be the major problem of the exercise.
A hinge wouldn't break for no reason. I think it would be wise to discover the reason before carrying out a repair. I suggest checking the price and availability of a new replacement hinge from the manufacturer before going ahead. The broken hinge might be a design flaw (whoever heard of a broken oven door hinge?) and a replacement might be a modified part that would resist breaking.
It is possible a new part could be cheaper than having it welded but you won't know until you check.
Apr 02, 2016 | Ovens
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Kenmore 110.62622101 dryer door hinge is broke
It will be as you are facing the unit.
Sep 08, 2014 | Kenmore Dryers
Change door hinge lower on 2010 dodge calaber
alot of new cars only the door half is changeable the other is welded to the body. you can buy pin and bushing kits
if the body side is egg shaped you will have to weld the hole up n redrill it (weld will temper it good luck with this) if not bad bushing kit will work. local wrecking yard is cheapest for door side if needed. use a jack with a piece of wood on it to support the door
when you take the hinge off be carefull not to stress any wires that go thru the boot into the door
Aug 15, 2014 | Cars & Trucks
Can't get the door back on
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 09, 2013 | Dryers
Stripped hole in door jam
There should be a plate that has been taped or a nut wellded on the
other side of the fram ether way have someone weld it closed and retape it, or have new nut welded on the oposite side of the hinge
Jul 26, 2012 | Cars & Trucks
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Weld on drivers side top door hinge broke door will not open without falling off how do you fix this
You will have to have it welded back on. Probably have to remove front fender to do it right.
Feb 19, 2010 | 1998 Jeep Cherokee
93 Jeep Cherokee Sport: Door Hinge Plate Came Off
dont weld it first drill and screw it on 2 screws to see if it lines up and closes all right then have it mig welded leave screws in till welded then just totch it up
Aug 02, 2009 | 1995 Jeep Cherokee
Frigidaire microwave door fallen off
I had the same problem. I removed the door and used a rivet tool. I checked to make sure the door cleared the rivet head, which was nearly flat, so there would not be any microwave leakage.
Jun 28, 2009 | Frigidaire GLMV169D Microwave Oven
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
