Question about Baumatic 24 in. BFD60SS Free-standing Dishwasher
Dishwasher have a dishwasher that does not clean the dishes properly. It leaves stuff that looks almost like sand on the top of all the dishes on the top rack. I have tried everything I can think of. can someone help me figure this one out
  • 288 Answers
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Posted on Nov 05, 2007
2 Suggested Answers
  • 5 Answers
SOURCE: I have a dishwasher that does not clean the dishes
dishwasher may not be draining well. It may be dirty water
Posted on Jul 21, 2010
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishes not getting clean
the problem is hard water leaving the residue. go to and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Dec 01, 2008 | Maytag MDB7100AWB Dishwasher
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Baumatic 24 in. BFD60SS Free-standing Dishwasher Logo
629 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
