Question about Emerson LC320EM8 32 in. LCD TV
The on light keeps blinking but the tv will not turn on
    President:
  • 1,077 Answers
Hi, I own the same TV and had the same problem.
It's the #1 plaguing issue with flat panel TVs made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TV is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you. Sorry I didn't get to you sooner.
Posted on Jul 13, 2009
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
Hitachi UltraVision Tv Keeps turning off. The lamp LED blinks. Both light engine and lamp are new.
google.com/+GopakumarGopalan
Nov 13, 2013 | Hitachi 50V720 Television
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Sep 05, 2012 | Sharp Televison & Video
Power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Jul 23, 2012 | Curtis-Mathis Televison & Video
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
My TV will not turn on. Power light is blinking
my 32" panasonic lcd t.v will not turn on but the red light keeps blinking in front?
Oct 12, 2009 | Philips Ambilight 2 52 in. Flat-Panel LCD...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Emerson LC320EM8 32 in. LCD TV Logo
237 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
