Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
Oiler not working, need diagram to fix
Took oiler and oil line apart can't get back together
  • 86 Answers
HI. IF YOU GOT YOUR SAW NEW THERE SHOULD OF BEEN A DIGRAIM SHOWING YOU HOW IT WORKS. THATS THE BEST YOU WILL GET UNLESS YOU KNOW SOMEONE AT THE SAW SHOP BECAUSE THEY DON'T WANT YOU TO KNOW HOW TO TAKE THEM APART AND PUT THEM BACK TOGETHER. GOOD LUCK. JIMBO
Posted on Sep 14, 2009
CS302S. How do I replace the oiler?
Although oilers do fail, the most common cause is simply an obstruction in the oil supply line. You can test the line by simply applying a small amount of pressure on the oil reservoir (usually, most of us put our mouth over the hole and pressurize the oil line). If you do not see oil "oozing" out of the plate, where the chain passes by, then you have a blocked line. Make sure that you have remove all of the wood chips out of the line and then try to pass a small wire back through the line - if successful then recheck the line by pressurizing it again. If that doesn't work, disassemble the saw and replace the feed line from the tank to the oiler. If you do have the old style manual pump for oiling - take it out, clear it, and put it back.
Oct 24, 2015 | Echo Garden
I have a 99 ktm 250 sx. Had to get cylinder replated and a new piston. I put the bike back together and oil was leaking from the front lower end of the cylinder and i wont idle. Took the bike back ap
If there is a leak in the head gasket it will never run properly. Maybe the carburetor is plugged if it has sat for a while. The gas/oil mixture can go bad over time. The leak could be from a loose gas line. Or possibly even oil dripping from the oil filter if you just cleaned and re-oiled it.
Aug 10, 2013 | Motorcycles
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Auto oiler problem on a stihl its not oiling thanks for your help
Sometimes it gets dirty .
You need to take it apart and clean it very well .
Carefully put it back together .
It will help.
Dec 23, 2009 | Garden
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
My paslode will not drive a 3 1/4'' nail in pine lumber, but it will drive a 2'' nail in the same lumber. i have took it apart and cleaned it with the paslode cleaner and used the paslode oil put it back...
check your air tank for moisture , drain it and put a oiler on it, or just oil it your self. put at least 3 to 4 drops run the proper amount of air they want you to run.
Jul 25, 2009 | Air Tools & Compressors
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Jun 18, 2009 | Standard Oregon Chainsaw Chain For...
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
202 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
