Question about Element Electronics FLX2211B 22 in. LCD TV
Why Element TV "Not Support" with Sony DVD HDMI?
How do I set my Vizio tv up so it will let me watch movies on a Sony DVDs player
Assuming the DVD player has an HDMI port, run an HDMI cable from the DVD player to an available HDMI port on the TV. Let's say you have your TV service going to HDMI #1 on the TV, you can run the DVD to HDMI #2. When you want to watch a DVD, you must select the input/source on the TV remote to change it to HDMI 2(or whichever port you used). When ready to watch TV again, use the same button to change back to HDMI 1 (or whichever HDMI port you used for TV service). If you do not have an HDMI port on the DVD player, then you must use whatever type of connection it has and connect to the corresponding port(s) on your tv, Then follow same directions as above regarding choosing the input/source on the TV remote.
Dec 02, 2017 | Sony Televison & Video
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
I have an Element EDHFT12 hdmi player and can not get it to play in hdmi. It shows no signal in hdmi
Make sure the audio output in your system setup, is set to HDMI output. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 28, 2013 | Element Skateboards Element EDHFT12 DVD...
How do I switch from coax to hdmi on my Sony receiver?
on the sony site it says the hdmi into the reciever is for the video, relayed by another hdmi to the tv, the audio will still be the coax
I personally would use the hdmi from dvd directly to the tv, and the coax from dvd directly to the reciever and call it a day
Mar 08, 2013 | Sony STR-DG510 Receiver
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
No sound/no picture
Never realised you needed Audio Cables w/ the HDMI
Jan 06, 2009 | Sony HDMI Single Disc DVD Player
Element Electronics FLX2211B 22 in. LCD TV Logo
55 people viewed this question
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
