Question about RCA DRC630N Portable DVD Player
Reads cd but not dvd
Reads/plays cds but not dvds
When using DVD, the laser/lens assembly seeks for about a minute and then stops
Cleaned lens - no effect.
Tried to calibrate DVD potentiometer on laser assembly - no effect.
Calibrated CD OK.
Some DVDs will play for about 10 seconds then pixelates and stops.
snakehead
  • 1074 Answers
SOURCE: Cd Player
i need to know if it was playing cds before then i will be able to help, my email is nicodhem@yahoo.com
Posted on Mar 23, 2007
bigg t
  • 640 Answers
SOURCE: Not being able to play burnt dvds or cds
you have to make sure your player supports the format your using on the dvds/cds.possible formats iso,avi,mp3,mp4 ect ect
Posted on Dec 30, 2007
SOURCE: DVD player says "wrong disc type"
Clean the laser.
Posted on Mar 17, 2008
vykana
  • 8 Answers
SOURCE: Spongebob dvd player does not load dvd
that means the dvd's reader has to be replaced or try to wash the dvd then dry it with a tissue then put it in the dvd
Posted on Mar 27, 2008
SOURCE: dvd player RCA DRC245NTV
did you try cleaning the eye with alcohol?
Posted on Aug 07, 2008
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
My dvd player will not play any dvds or cds... It says disc error
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say disc error.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | Audio Players & Recorders
Nd 3550a will play and record cds and records movies with sonic 5.3 but will not read or play dvds in any mode. drive does not show disc in machine. Running xp dell 4600
For playing DVD's you need to install DVD softwares which is came along with the drive Or download and install the same from vendor website will resolve your problem.
Revert back for more assistance.
Feb 01, 2010 | NEC ND-3550A DVD RW Dual Layer Burner
Keep getting a no disk error. how do i fix this? is the lens dirty? these are all new dvd's
This can be as simple as a dirty lens as you suspect or a defective optics assembly. Remove the cover and clean the lens with a cotton swab and alcohol. If that fails to allow the unit ti play DVDs, try a CD. If the CD will play, then the unit is likely to require new optics. CDs require less laser power to read then DVDs.
Dan
Nov 26, 2009 | Samsung DVD-1080P7 DVD Player
Will only play cd not dvds. lens turns red . plays dvd then stops by itself but no problem with cds
HELLO
This sounds very much like a laser problem. ALL DVD players have a dual laser (one for CD other for DVD). It is very likely that the DVD laser has gone defective that is why you can only play CD's.
Another thing you can try is to clean the laser lens using isopropyl alcohol and a cotton bud - laser may be dirty/dusty as this can cause problems too.
If after cleaning the lens you can still only play CD's, then the laser will be defective. This will be an expensive repair job therefore it's cheaper to buy another unit.
ALL THE BEST (:-)
Sep 12, 2009 | Durabrand DUR7 Portable DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Trutech 17 inch tv dvd player the dvd spins seems not fast enough
The first step is to clean the lens of the optics assembly (if you can get to it) carefully using a cotton swab and alcohol. If that does not resolve the problem, try playing a music CD. If the music CD plays but a DVD does not, it suggests that the laser is starting to fail and needs to be replaced. CDs require far less laser power to read than DVDs.
Hope this helps,
Dan
Dec 10, 2008 | TruTech PLV16320 Television
I have a portable dvd player model number mdp1030 the unit keeps saying no disk I have tried numerous disks same results.
then i think the lens is not able to read the disk.
and so i would suggest you to buy a disk cleaner CD and run it in your DVD player and then use your regular disks.
if this is not working then it is some internal fault in your DVD players lens.
Aug 13, 2008 | Mintek Televison & Video
DVD Player structs after playing 10 minutes of video
the heat from the infra red laser heats up the disk to the point it is hot to touch at which point the read lens cannot read the laser reflection thru the heat noise. cool it down, keep a small fan blowing thru it or play shorter movies.
Jun 20, 2008 | Daewoo DVDS151 DVD Player
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
RCA DRC630N Portable DVD Player Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
