Question about HP DeskJet 1220c InkJet Printer
HP printer will not feed paper.
My HP Officejet J5780 printer all of a sudden stopped picking up and feeding the paper. I have cleaned the rollers in the back door and still the same problem. Also the message indicator reads out of paper when it is not. I have tried putting in single sheets, pushing them in a little, no luck. I tried putting in new ink cartridges, but the same problem applies (and now I get a message reading to allign paper). Any suggestions to get the printer to feed again? Thank you very much.
    Guru:
  • 224 Answers
Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
    NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again. If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product call in to hp at 1800-474-6836 and ask for an upgrade on which you shall get atleast a minimum of a 50% discount on the printer cost.
Posted on Jun 25, 2009
Paper wont feed on HP Officejet H470\
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Jun 30, 2011 | HP Officejet H470 InkJet Printer
Paper will not pick up and feed thru printer
You pick-roller is to dirty and need cleaning.take a clean cotton or cloth peace and with spirt clean the roller.If you look in the paper tray you will see the pick-up roller.Replay if you need futher help!
Nov 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The auto document feeder does not pick up the paper
The pickup roller is probably dirty. Take a clean sheet of paper and put a small amount of rubbing alcohol at the end. Take that same end and place it in the automatic feeder and attempt to feed through for a few times. This should clean the pickup roller and allow paper to be picked up. Wait a few minutes for the alcohol to dry and attemt to feed a clean sheet of paper. You might need to repeat the process a few times
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Line feed problems. give 1/2 line feed. document feed sounds like it needs 'oil'
While HP may use a little white grease on some plastic gears, oil is not normally used. Most likely some debris such as paper dust, or part of a label, or a stray staple is jamming the mechanism.
If it's all clean, then I would look closely for a damaged gear of some sort.
Most printers rely on rubber feed rollers of some sort to pick the paper from the paper tray, then more rubber rollers to pull the paper through the mechanism. If the printer is relatively new, the rubber rollers should be in good condition. As the printer ages, these get less rubbery and more slippery, and wear out, leading to feed problems. Further, any contaminant such as oil, white-out, or a sticker on the feed rollers will render them useless. Printer technicians change a lot of these rubber rollers.
Oct 16, 2009 | HP Officejet 7210 All-In-One InkJet...
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Won't print
Hi, try a smaller quantity of paper in the paper feed tray. Also check the paper pick-up mechanisms rubber roller for too much smoothness. If the rubber roller feels too smooth, Use a lint free cloth dipped in alcohol to "clean" them.
Apr 30, 2009 | HP Officejet 7210 All-In-One InkJet...
My printer stopped picking up/feeding paper. If I
try cleaning the pick up rollers , they must be a little sticky
Apr 03, 2009 | HP DeskJet 5550 InkJet Printer
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
HP J5780 all in one printer
jahomner,
Your problem is one of two things. the first is that the paper settings for your machine is not set to plain paper. the unit will adjust the gap size to suit the media coming through the unit. check that your paper is set to plain a4 or plain letter, dependant on your location around the world.
the other issue is simple wear and tear on the unit. the seperation pad and feed rollers in your document feed assembly may be dirty or worn out. you can clean the rollers with some alcohol, however this does not fix your problem, that the chioce is replacement of the unit as HP do not supply spare parts for their inkjet range of printers.
Gremlin11
Dec 05, 2008 | HP Officejet J5780 All-In-One InkJet...
HP DeskJet 1220c InkJet Printer Logo
848 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
