Question about Boating
Aireator wont work
I have fire at the switch, bought new switch. If i power directly to aireator it will work but not from switch. 95 basstracker 60 proseries johnson
abe
  • 5,687 Answers
Try this. When you bypassed the switch did you use both positive and negative wires? What I am thinking is you need to figure out if you have two problem wires or one. You might want to check the negative wire for continuity. I assume you checked the hot wire at the aireator. Remove the new switch if that did not fix it. Check your poles behind the new switch for continuity. Sometimes the poles connect up and down on one side instead of across both sides.
Posted on Jun 25, 2009
  • 36 Answers
Track the wiring back to the fuse box, check fuse or relay, keep tracking all the way to the battery, there is usually another fuse or breaker in line before the fuse box, may be hard to find.
Hope this helps
I just bought a 95 jeep wrangler and the wiper motor wont work? I replaced the motor and fuses any advise
Have you checked the wiper motor for power and ground from the wiper switch? Possible wiper switch
Nov 08, 2015 | Jeep Cars & Trucks
95 monte carlo passenger side window wont work
When a window switch is not being used, it has the ground circuit on both sides. Then when you move it to up or down, you apply power to one side of the motor. Thats how the motor is able to run in both directions.
So you should have power on one side or the other when you move the switch. Have you checked it for power and ground ?
Jul 26, 2013 | 1995 Chevrolet Monte Carlo
95 honda civic hatchback wont start
Did you hooks the the spark plug wires right. If these are not in the right order then you will have a misfire. If enough of them are out of place then you wont have enough fire to start the engine.
Mar 03, 2010 | 1995 Honda Civic
Ignition bike wont start
check the battery coil wire
Feb 28, 2010 | RTO 50cc Moped Scooter
My 95 f3 will crank but wont start. everything was working fine replace a headlight now it wont start with the starter. battery is charged and i can push start it but the engine just cranks and cranks and...
Sounds like a wire or plug got disconnected while changing the headlight out, the harness that connects to the clutch safety switch, the one that lets the ignition fire when cranking only when the clutch is pulled in. A safety feature so you don't dump the bike if you crank it while in gear.
Sep 12, 2009 | 1997 Honda CBR 600 F(3)V
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
