Question about Dell E153FP 15" LCD Monitor
My monitor will only stay on for a few second and then goes black. The green light stays on.
  • Dell Master
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor shouldwork fine. The capacitors do need to be installed with the correct +and - connections, note the stripe on the old one and insert the newone the same way. If you don't want to try the repair yourself we offera repair service for $35 plus shipping. I hope this helps, if so pleaserate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 26, 2009
Monitor stays on for a few seconds then goes black
could be your wires or your moniter itself check those replace the wires and see what happens if it doesnt work just pm me
Feb 26, 2012 | Dell E173FP 17" LCD Monitor
Monitor come on for a few seconds then goes black,green signal light stay on green. can you help
the monitor may be losing the back lite. take a flash light or bright light and shine it at the screen after it goes black. can you see a faint picture? if so the back lite has failed. usually the cost of replacement exceeds the cost of a new monitor but there are a couple of web sites that detail the replacement of the "ccfl" cold cathode flouresecent light.
Apr 27, 2011 | Proview PL713B 17" Flat Panel LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor stopped working...checked all connections...light won't stay on green. bought a new monitor to replace it and that monitor says "no signal". is this a problem with the dell computer and not the...
Your monitor is going into power saving mode. When it receives no video signal from the computer, it will stay powered for a few seconds before giving up and presuming the PC is off hence why it stays green for a while, then goes orange.
The problem is with your PC not the monitor(s)
Jul 07, 2009 | Dell Computers & Internet
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Moniter
does it display a picture for a few seconds before it goes blank. or do you not get any picture?. i think i might know what it is but if you could let me know :-) All the best John
Mar 02, 2007 | BenQ T701 TFT 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell E153FP 15" LCD Monitor Logo
623 people viewed this question
Alun Cox
