Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Why did my dryer stop getting hot?
My dryer is not putting out heat.
  • 5,911 Answers
First, verify the voltage at the wall receptacle to ensure you are reading 220-240 VAC across the two hot leads (LEFT and RIGHT slots on the recepatacle). If the voltage is incorrect, the dryer may still run, but won't heat.
The number one cause of dryer heat related problems, or longer dry times, is poorly installed, or clogged ventilation. If you haven't checked the dryer ventilation or cabinet interior anytime recently, now might be a good time to do so.
A simple test to try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the exhaust should be forceful and warm (about 140 degrees).
If the air flow is normal, and your clothes dry normally, the problem is with your exhaust ducting from the point where it leaves your dryer to where it exits your home. I would recommend you inspect the entire length of your exhaust ventliation to make sure it is free of kinks or clogs if this is the case.
If the air flow is weak, then the problem is INTERNAL to the dryer. The most common source of the problem is a clog in the blower fan housing preventing air to flow properly. Remove the blower fan housing cover and clean as necessary. Make sure the blower fan can turn unobstructed.
If the dryer is running and you confirm there is sufficient air blowing from the exhaust, but still have no heat, the following link explains how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
In the majority of cases, the Thermal Cut-Out (TCO) fails. The TCO and Hi-Limit thermostat are located on the outside of the heater box. If one or the other of these components is discovered to be bad, it is recommended that you replace BOTH of them. Failure to do so, can result in premature failure of any parts you replace.
Make sure you verify the dryer ventilation is clear prior to operating it with new components. If left in a clogged or poorly ventilation condition, the dryer will overheat to the point of failure. Not to mention, this can cause a fire hazard.
Let me know if you still have problems. I hope this helps you.
Posted on Jun 25, 2009
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Dryers
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
My front loader dryer stopped heating,
have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
Jun 22, 2009 | Maytag MDE9206 Dryer
Dryer got very hot when shut off,wouldn't heat up when running.
We took apart the dryer. the heating coil was broken in two. When the dryer was stopped it was not in off mode therefore the electricity was going through and the ends off the coil where it was broken was touching the metal and eating the dryer which made it hot to touch. We tested the 3 different fuses? the ohms were good. Ordered the part waiting to put it back together to be sure. Rule to remember even when dryer is stopped it should always be put in off mode.
Jun 02, 2009 | Frigidaire FSE748GF Dryer
Electric dryer not blowing hot air
Sounds like the heating element is not working, make sure you are getting 220 volts to the recptical. Let us know if that did the trick. If not let us know thankyou
Mar 15, 2009 | Dryers
Dryer gets hot then stops mid cycle
hi
is the heating element and motor belt is ok,,check that
,,,,,,,thank u
Mar 07, 2009 | Whirlpool LEB6200 Electric Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer gets hot when not running
Getting hot when not started is a great concern.
I have a few ideas why, but this is a fire hazard and I would suggest unplugging and either getting help or replacing.
That said, there here are a few suggestions.
1) if the element is shorted to ground, it will get power to one side of the element and heat though ground. This, again, is serious.
2) if it heats forever and doesn't get warm enough to dry, this is another indication of an element that is not working up to power. Not getting 230 across the entire element and not getting hot enough to dry.
3) Many times when a dryer runs too long, the air flow if blocked by the vent being plugged or some plug withing the dryer itself.
Again, I am very concerned about this problem and suggest you not use it until it is repaired. If you want to check the element, it is fairly easy, but unit will need disassembled.
Mr Boo
Nov 30, 2008 | GE Dryers
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
916 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
