Question about Homedics Pa Mh Therapist Select Compact Percussion Massager
Homedics household massage QRM-400A powers up intermittently, then just died. Pls help.
2 Suggested Answers
SOURCE: Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
I have the model qrm-400h and I did mistake gave 240volt current now does not work I live in Greece how I resolve the problem
I do not know what the voltege is for the threpest Cussion if it was bought in the us the voltege 110 if this the case you could have burnet it out I live in Australia and we can use them there because we have the same voltege 240ac
Jun 02, 2014 | Homedics Qrm 400h Therapist Select Quad...
Power light flashes continuously. No response from the unit other than light on the "wheels" of the messager. Model QRM-400.
Good day!!!
that problem has 2 causes its either power supply board or main board/control.....
please check the power supply...
faulty(leaky/dried) electrolytic capacitor in the power supply section. In the first stage of symptoms warm up will make itself stable and the unit will power up after a few attempt of plugging and unplugging from the outlet but it will get worst, time will come that the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify like in the sample picture below.
Leaky capacitor with dome at the top.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition, if not available you should replace all electrolytic capacitor in the power supply section. It will not cost you much because it is one of the cheapest parts on that board.
Click this LINK for more information regarding electrolytic capacitor.
If the power supply is stable and no bulged capacitors...The problem is on the main board..
if the main board is defective,,that is not for D.I.Y because the sensitive parts inside and usually the parts are surface mount type..Please replaced it with the new board..
but before you replaced the board please try to check first the power supply as I first mentioned..
if you have multimeter its better..just check the Vcc 5vdc..if have voltage drop..
Jul 29, 2011 | Homedics Quad Roller Shiatsu Style...
Need a power adapter for the homedics sbm300 massager
No longer available from Homedics. Just called them today and found this out.
May 29, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Hi, I have got brand new Homedics shistsu massager cushion (MCS-360H). When I am plugging it in, I can see that power button in the remote is not getting started. Can you please assist me with this...
Hopefully you've got the right model listed here, as the MCS-360H is a Swedish Massage Cushion.
Did you remove the screw from the back of the unit before plugging it in...? The unit will not work properly until that screw is removed, and could be damaged if it is operated with the screw in place.
Here's the manual -
http://www.homedics.com//media/documents/homedics/instructionbooks/MCS-360H_IB.pdf
If removing that screw does not make the unit operate properly, contact Homedics Customer Service at 1-800-466-3342
Oct 02, 2017 | Homedics Shiatsu Massager
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
I have a Shiatsu Massaging Cushion....it will not operate...blue power LED blinks.
This link take you to Homedics web site...to the right of the picture you will see "Support Information" click that tab to download a useer manual....I hope this helps.
http://www.homedics.com/products/massage
Jan 03, 2009 | Homedics Shiatsu Massager
Homedics Pa Mh Therapist Select Compact Percussion Massager Logo
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
