Question about Lanzar VIBE286 Car Audio Amplifier
Well the hear unit is a pioneer dehp60000vb and the truck is a work van the anp is installe on the front wall that splite the back end of the truck and in the back of the wall i have 2 15"lanzarmaxpro i have 4 caps on system. its a gmc van allso have a600 w anp for the fornt of the truck 6.5 twitter and 2 10"
    President:
  • Lanzar Master
  • 1,114 Answers
If you have the amp bridged mono to run both 15's, it's gonna get smokin hot. That's the nature of the beast. Just make sure it's got plenty of room around it to breathe, if you want to put fans on it, just make sure the fans you buy are DC voltage and noise shielded. If you surf the net you can find lots of electronics parts providers out there, just explain to them what you are trying to accomplish and that you do not wish to introduce ignition noise into the system and need a quiet running fan. That will at least keep air moving across the unit and draw heat away. End result, it can't hurt. Hope this helps
Posted on Jun 26, 2009
Dodge van 3500
check steering ball joints for wear. Check for loose wheel bearings. Check front end suspension
Aug 15, 2014 | Cars & Trucks
I own a all wheel drive astro van and the front end is leaking oil and now the all wheel drive doesnt work
Hi there avalanche426, I am sorry to hear your dilemma. What it sounds like has happened is your Astro's front differential has leaked enough fluid to prevent it from doing its job. Try filling the differential to where it needs to be and see if it starts to work again. If it does drain the fluid and replace the gasket the is leaking then refill. If it still doesn't work after filling it back up it will be because too much damage has occured.
Apr 06, 2011 | 1998 Chevrolet Astro
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Vibration and noise from front end while driving
Jack up the front end and put stands under it and block rear wheels. Look at axle boots and see if they are cracked. Try turning wheel back and forth sharply and see if you can hear any clicking. Problem could be outer axle joints. If the boots are cracked or you hear a clicking noise you will have to replace the axle. The axle and boot come as a complete unit. Please let me know what you find out.
Apr 13, 2009 | 2002 Chevrolet Venture Passanger
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer Avic D2
I suggest u to take it for a general service, this includes lubricating and cleaning and alignment.
Hoping a rating from you...!!!
Thankyou
Feb 15, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Cannot record DVD-R's
I could not record DVD-R's on my 633H.
Calling Pioneer I was told that I had to use DVD-R's rated no more than 4X.
I ordered 4X DVD blanks and have not had a problem since.
However, when I told the service man at the hi-end store where I bought the unit what Pioneer had said and that it fixed my problem, he said it was baloney and to bring it in and he'd have them fix it - that it should handle DVD's supporting higher write speeds.
I didn't take it in as the 4X blanks are cheaper and I don't want anyone mucking around in my machine when it is working OK..
Oct 30, 2007 | Pioneer DVR-633H-S
Woofer problem
If I am not mistaking here, you need a self powered subwoofer to use with this unit. Those are line driven outputs for this unit. Make sure there is a wall plug on the sub that is plugged in. Good Luck
Jun 07, 2007 | Pioneer VSX-516-K/S Amplifier
Lanzar VIBE286 Car Audio Amplifier Logo
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
