Question about Microsoft Windows XP Home Edition
Missing File ''PRORET.MSI''
When trying to install service pack 3 I get the message asking me to insert disk to find file ''PRORET.MSI'' - unfortunatly i cant find the disk. is there anyway around this?
subsequently windows update tells me
Installing Office XP Service Pack 3 (update 1 of 3)... failed!I
Im running Windows XP with IE8
Any help appreciated.
thanks
    President:
  • Microsoft Master
  • 1,996 Answers
This will probably help. Click here and here.
Make sure you scan the downloaded file with your AV before you install it. Then try the update.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 25, 2009
I am missing installation package 'ei_98.msi' how do i get it back
When thy system asks for the file insert the OS disk and it should install it from there.
Aug 10, 2014 | Dell Computers & Internet
It show windows name roxio update manager when I press browse it ask file name : UM.MSI and file type : Istallation Package
If you have the Roxio disk , insert the disk in the cd-dvd drive -point the browse location to the drive letter for your cd-dvd drive and click OK.....it should update the msi source packages and correct the issue. I assume this is requesting the original source packages and location. Possibly due to some corrupt or missing files. Will need more details on the message. If that does not work you may need to uninstall and re-install roxio. If it came pre-installed on your pc go to the manufacturer web site and update or download and install roxio from there. Hope this helps....
May 11, 2011 | Computers & Internet
I have problem with Widows instaler ,PRORET.MSI is needed where i can find it ?
http://rapidshare.com/files/427028208/proret.zip Download and unpack.
Oct 25, 2010 | Microsoft Windows XP Home Edition
How to fix Trayapp.msi missing problem
Do you have the installation CD?
If so here is how to remove it..
1st Insert the disk into the CD-ROM.
2nd With the message displaying trayapp.msi is missing click the browse button
3rd - Select the cd-rom drive click/ open the setup folder, then open the trayapp folder.
4th - select the trayapp.msi file and double click on it to open it.
5th - this should return you to the install wizard and finish walking thru it.
if you do not have the disk..
download the software program from HP's website:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=445197&lang=en&cc=us&prodTypeId=18972&prodSeriesId=445194&taskId=135
Select your operating system.
Click on Software or scroll down to software.
Download the correct software based on you region.
Then un-install the existing software program, reboot your computer.
Then install the software you just downloaded.
Oct 21, 2010 | HP LaserJet 2840 All-In-One Printer
My computer is missing important system files
> type the path ...
Specify: C:\WINDOWS\ServicePackFiles\i386
as the "path".
Jun 23, 2010 | Computers & Internet
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Error code 2329
It's a error message with Windows installer not for Itune.
Try to get latest windows installer from link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
Supported Operating Systems: Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows Server 2003; Windows XP; Windows XP Service Pack 1; Windows XP Service Pack 2
Dec 28, 2008 | Computers & Internet
Office XP Service Pack 3 (SP3)
u can download the sp3 from the microsoft web site www.microsoft.com
Mar 16, 2008 | Microsoft Windows XP Professional
Magix Music Manager
Is it really asking you for ur software installation CD?
Most probably it may be asking you for your Operating System Installation CD. Please insert the Windows 2000 SP4 CD into the drive and try continuing with the installation
Best of luck
Have a nice day
Feb 01, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
4,716 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
