Question about Car Audio & Video
My street glow underbody kit turns on then off immediatly after switch is pressed. Light shows then immediatly vanishes with switch still on. I turn off the switch and it does the same thing again. Streetglow lights will not stay on constantly.
  • 365 Answers
Chances are your ground is bad...re-do the ground source and try again.
Good Luck
Posted on Jun 26, 2009
Is oil light suppose to come on before starting bike just changed oil and filter theres 3 holes in window for oil
When You Turn The Switch To The On Position. The Oil Light Should Be On This Basicly Shows That Bulb Is Good. When Engine Starts And Is Running The Light Should Go Out Immediatly Indicating Oil Pressure.If The Light Does Not Go Out Shut Engine Off Immediatly And Investigate.OIL Level , SENDING UNIT, Loose Wire At SENDING UNIT.
Mar 17, 2013 | 1995 kawasaki GPZ 1100
Glow plug light comes on then off
The glow plug light comes on to show that the glow plugs are warming up. You should not start the vehicle until the light turns off, as it can damage your glow plugs. The light should turn off after a few seconds while the ignition switch is in the on position. In short the vehicle is working properly.
Nov 11, 2012 | 1992 Ford F250
I have installed the custom auxiliary forward lighting kit on my street glide. I have followed the wiring installation instructions to the T and the problem is that the head light and the auxiliary lights...
Some circuits need everything plugged in so you can get a ground so everything works correctly. Can you provide a ground to the new items? I am guessing that you have the fairing open and are trying to check this all out before you button things back up? Check out is your ground completely. Use a test lamp and connect it to a ground at your lights then to the other end to your negative (-) terminal on your battery. This may sound strange but if you have a bad ground your test lamp will provide a better one and the light will glow. If it is a really bad ground your light will be bright if it is just a weak ground you may see a dim glow from your test light.
Since you are already in there you know how sharp everything is. I would look over the wires and wire loom to see if you have any wires that the insulation has been cut thru.
I would check to see if you have power at all locations. I am guessing that you have a multimeter so you can see voltage and continuity to ground.
Regards Outback
Apr 25, 2011 | 2008 Harley Davidson FLHX Street Glide
Refresh rate will not switch to 60 hertz from 59 hertz. Hence my hdmi connection from my desktop to my display keeps showing "out of range" error
turn off the computer restart it and press F8 immediatly before start and keep pressing untill menu appears then highlight on" enable vga mode" and press enter your problem will be solved
Apr 05, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
After reseting Asus vw192s I can´t have the normal color, It tries to autoadjust, for a second it is all fine and then turns into a darker colour, more blue. Don´t know what to do.
I have the same problem and you can fix it by entering in factory service mode:
1. Turn the monitor ON
2. Turn it Off
3. Press and hold MENU button and turn the monitor ON, led should glow orange
4. Press MENU again and service pop up will show up
5. Choice AUTO
Blue color on my screen vanished.
I have found this solution on polish forum.
http://www.elektroda.pl/rtvforum/topic1949561.html
Dec 30, 2009 | ASUS VW192S Monitor
Glow plug error
When was the last time you had your timing belt replaced. Did you do it yourself.
I had mine changed last year and I have known for an entire year that the timing was off slightly. The check engine light WOULD NOT turn off not matter what I did and it kept reading a bad glow plug.
I finally fixed the timing (the camshaft sprocket was off only one tooth) this past Sunday and the check engine light finally turned off all by itself!
Not sure if this fixes your issue, but, it fixed mine.
By the way, if you need the tool kit for fixing your TDI's timing, by it from dieselvw.com. This guy sells a 3 piece kit for $49 where other websites sell a two piece kit for $125 or MORE! I used the kit and it worked flawlessly and the extra piece (the tensioner wrench was handy!).
Apr 05, 2009 | 2002 Volkswagen Jetta TDI
Tomtom xl 330.s wont speek street names
Yes Nickarino is right.
When I switched on my new tom tom it gave me that option to speak street names and it vanished after selected a different voice. I checked all manuals and web references in Tom Tom - none of them list it.
Like Nick said - what you need to do is swtich the voice type to SAMANTHA and it will show the option "Read Street Names Loudly". I jumped on it and said yes ..!!!
Thanks Nick !!
Dec 26, 2008 | Tomtom XL 330S GPS Receiver
2000 ford excursion 7.3 diesel wont start
hi.check the start selenoid on the pass side of the engine in the engine valley it has 2 battery connections and a little wire it turns on the glow plugs the wire might be comprimised look for the wire chaffing or insulation rubbed off. does it blow out immediatly or over time?
Dec 07, 2008 | 2005 Ford Excursion
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
