Question about Patton (HASF1016UC) Stand (Pedestal) Fan
I have a patton floor fan that needs a switch E87438 308 A for the motor. Do you know where I can buy such a switch?
    Problem Solver:
  • 6 Answers
SOURCE: replacement fan blade for fan
I have one of these pieces of junk. The motor swarmed, so the rest of the fan is perfect. I'll sell it for $10.00 plus shipping.
Skip marinaman@aristotle.net
Posted on Jul 17, 2008
issy2
  • 462 Answers
SOURCE: Blade for Patton Stand Fan Model 1010-MP1
does it have a slight bend or a worst one.. generally these blades are quiet to replace... please tell us where u stay...
Posted on Sep 09, 2008
PegBox60965
  • 51 Answers
SOURCE: Looking to replace Patton fan motor, model 1010mp, style TJ74SP
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Posted on Jan 01, 2009
  • 57 Answers
SOURCE: Any idea where I can get replacement metal fan
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Posted on Jun 10, 2010
SOURCE: Where can I buy a rotary switch for a Patton U2 1879 floor fan?
You can check with the local hardware store.
Posted on Nov 09, 2010
The Patton Floor Fan I have quit working when a shirt was sucked into it and no-one was home. I am wondering if they have a fuse on the motor that can be replaced?
Most have a one-time thermal fuse wired into the motor. You would have to remove cage and fan blade, unscrew motor mounts, open motor casing, locate fuse by cutting open or sliding off the thermal sleeves, cut fuse out and resolder a new thermal fuse in. Should be able to locate replacement thermal fuse online. Can also just splice ends together but then you lose thermal protection and a fire can result. It is a good temporary fix to diagnose if you have burnt out one of the motor coils.
Oct 01, 2014 | Patton Dryers
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
Oct 09, 2012 | Patton U2-1887HO Floor / Box Fan
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Aug 17, 2011 | Patton U2-1487 Floor / Box Fan
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
Any idea where I can get replacement metal fan blades for a Patton floor fan?
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Replacement fan blade for fan
Jun 13, 2008 | Patton U2-1487 Floor / Box Fan
Motor seized
I just want to know if I can purchase a NEW motor and what the cost is?
Feb 24, 2008 | Patton U2-1487 Floor / Box Fan
Patton (HASF1016UC) Stand (Pedestal) Fan Logo
1,763 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
