Question about Acer Aspire 9300 Notebook
One long and two short beeps while starting
Hi, i got a problem starting my Acer aspire 9300 labtop it make a long and a short beep and get hang.-
And sometimesit just start normally and stays work for hours or days...
I want to know if is a problem related to a graphic harware and if it can be fixed inside bios or windows,
i will appreciate any help-
Thanks.
    Sergeant:
    Champion:
  • 253 Answers
Hi
this may be ur ram problem so get the ram of more memory
Posted on Jun 25, 2009
My acer aspire one beeps when i switch on 1 long 2 short and wont power up
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk, and remains active until turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive SATA
Make sure they have a secure dust free connections.
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate.
Hope this helps.
Nov 27, 2012 | Acer Aspire 9300-3716 Notebook
Acer Aspire 9300 1 long and 2 short beeps
Have the same problem and i solved it after 1 month tries
the problem was in NVIDIA Graphic card
the solution was by by heating the NVIDIA Graphic card for 5 min or more
Sep 26, 2012 | Acer Aspire 9300 Notebook
Computer beeps, minor flash on the screen, then shuts off
Computers follows a process which what we call P.O.S.T (Power On Self Test) to tests the computer to make sure it meets the necessary system requirements and that all hardware is working properly before starting the remainder of the boot process. If the computer passes the POST the computer will have a single beep (with some computer BIOS manufacturers it may beep twice) as the computer starts and the computer will continue to start normally. However, if the computer fails the POST, the computer will either not beep at all or will generate a beep code, which tells the user the source of the problem.
It depends on how long or how short or how many beeps did you hear to determine which hardware component in your computer is failing.
Here is a helpful link that you can check and follow for you to determine which hardware is failing in your computer.
After determining which hardware it is, I would recommend that you consult a Local Technician near your area, although, if this Acer Aspire is still under warranty with Acer, it will be better to contact them so that they can have whichever hardware part replaced.
Hope this information is helpful!
Apr 07, 2011 | Acer Aspire 9300-5005 Notebook
My acer aspire 9300 have beep code: 1 long and 2 short in start up..
This beep code is -
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
This is most likely a video problem.
Try re-seating the RAM, the video RAM is shared, uses part of the main RAM.
Also try restoring the BIOS setting back to the default settings.
Mar 03, 2011 | Acer Aspire 9300 Notebook
Acer 5100 hangs after desktop
this beep sound is geneally is due to the faulty ram.try having a loook at it.
Sep 10, 2009 | Acer Aspire 5100 Notebook
2 long and 1 short beeps while starting
Here is the Acer home support page for your notebook, with links to technical troubleshooting info that will help you to resolve this problem.
What is your OS? What kind of BIOS? Here is an article to help you troubleshoot the beep codes. Here is a good tutorial that will explain how to update the video drivers. That may be all you need to do...
Look in the Event Viewer and see what error or warnings are reported. If you right click on the id error code you'll be able to get help & support info on the errors there.
Another thing you could try is to run chkdsk (instructions here) to look for corrupt files on your hard drive that may be causing this problem.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 25, 2009 | Acer Aspire 9300 Notebook
Acer aspire 9300 black screen (display adapter)
I have been fixing computers that has long beeps and short ones. It is usually attributed to memory problem connection. Open the memory compartment at the back of the PC then detach the memory card. Clean with cloth softly enough not to destroy the circuit board or a pencil eraser to clean-up dust that caused the connection blockade. Reconnect after cleaning.
Jun 21, 2009 | Acer Aspire 9300 Notebook
Acer Aspire 9300 Notebook Logo
939 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
