Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward h100ID ignitor not starting - I turn on the heater after the winter and hear the fan but no ignition
    Problem Solver:
  • 12 Answers
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Posted on Jun 26, 2009
    Problem Solver:
  • 31 Answers
Re solder spark adapter on control board
Posted on Jul 04, 2009
Fan won't start and won't ignite I have a Hayward h100id
check voltage going in if ok check pressure switch should have voltage on both leads if not check pressure switch or copper tube for clog
May 26, 2014 | Hayward H Series Induced Draft Abg 100,000...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Jun 15, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
2,573 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
