Question about kawasaki Full Suspension Mountain Bike Men
How can the speed on a 179CC Kawasaki engine on a
How can the speed on a 179CC Kawasaki engine on a Huskey self-propelled lawn mower be slowed down?
3 Suggested Answers
SOURCE: I have oil blowing out of the dip stick on a JD
Nothing serious. A new o-ring for the cover. No more problem.
Posted on Jun 21, 2009
  • 11 Answers
SOURCE: I have a 14 HP Kawasaki engine on my John Deere
All the "safety" engine-kill "features" on this mower will ground the ignition system, stopping the engine and causing a no-spark condition. Check the seat switch, the brake switch. Also, the circuit board will cause the problem you have if it gets rained on, (the mower hood does not protect it); point is do not let the mower get rained on (or washed) unless you protect the PC board, which is right behind the ignition switch. Mine dried out and worked again but only after liberal spraying with (plastic-safe) electronic parts cleaner. You are right the manual would help, it's like $76 but it's in depth. Good luck, and PLEASE tell us what the solution was! -Tom
Helpful Deere lx176, lx178, hood hinge tip: If the hood hinge is broken on yours like on most, Deere has a GREAT repair kit that's only $10. They really priced it at cost or less to correct a defect they are aware of.
Posted on Sep 20, 2010
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Troy bilt self propelled problem
My only guess is you've put the cable actuator in upside down. Sorry, that's the only thing that makes any sense.
Aug 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
kawasaki Full Suspension Mountain Bike Men Logo
100 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
