Question about Akai LCT2715 27 in. LCD Television
Solid red light
I have a solid red light on my TV. It will not turn on. No power light is on.
Any suggestions. I would appreciate.
  • 6,784 Answers
The inverter board is damaged at this point. you will need to replace this failed board in order to restore normal functions.
Posted on Jun 25, 2009
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
My 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Apr 09, 2010 | Samsung LTM1755 17 in. HD-Ready LCD...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Akai LCT2715 27 in. LCD Television Logo
157 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
