Question about DeLonghi Pinguino PAC-02 Air Conditioner
My air conditioner fills up with water and shuts off.
    Genius:
  • 1,341 Answers
Check the drain pipe, there might be something blocking it somewhere.Hence it can't operate and shuts down.
Posted on Jul 05, 2009
    Sergeant:
  • 326 Answers
On the left rear theres a filler box with aflowter to stop systeme why wont it fill with water
The float is the condensate sensor.. It shuts the unit down when there is excess condensate in the bottom of the unit, and the unit needs to be drained. You should never try to fill the unit with water. If you have no water building up that is actually a good thing and it means the unit is working properly, venting moisture though the warm air duct.
Jun 22, 2013 | Windchaser PAC9 Air Conditioner
EVERY HOUR OR SO WATER IS POURING OUT OF THE DRAIN, WHY?
There is a float in the evaporative cooler that will let water in when the trough is low and then when it fills, should shut the water off. I would check to make sure that the float arm is not corroded or misaligned.
Aug 17, 2011 | Mastercool 67471 Evaporative Cooler Air...
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
Everstar MPM 08CR BB4
Set it so it doesn't have to work as hard (i.e. higher temp) and it will generate less water.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Windchaser air conditioner alarm light is on and it won't turn on
look at the water shut of float, as when the bottom of unit fills with water nor the bottom water float shut of gets stuck in the up position of the toggle relay itself get falty this will cause the proble you discribe
Jun 20, 2009 | Windchaser PAC9 Air Conditioner
Connecting a hose to take out condensation Danby dpac7008
you'll have to take it apart their is a switch which will have to be by passed .hook up your hose to a drain good luck . Tom
Jun 18, 2009 | Danby DPAC9030 Air Conditioner
Maytag portable air conditioner runs for 2-3 seconds then stops and shows code "E1" on the display
empty water & clean filter.. full water drain (which takes a few weeks to fill) will shut off the unit
Jun 08, 2008 | Maytag Heating & Cooling
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
312 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
