Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
My hotpoint HDA3400G is not draining and i am unsure if the problem is the dishwasher or a clog in my plumbing.
  • 6,784 Answers
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Jun 25, 2009
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Standing water in tank after cycle is complete
Check the drain filter and the final main drain hose connection. If the connecting junction point is clogged this could happen.
Sep 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Water sits in bottom of dishwasher and does not drain
If you have recently installed a garbage disposal the knock out the plug in it where the dishwasher drain connects to it. If not it sounds like the pump may be out or your drain line is clogged. Check the drain easiest way is where it connects to the pump disconnect it but make sure you go slow and you put a bowl under to catch the water. If you need any further assistance please contact me back.
Jul 08, 2010 | Hotpoint 24 in. HDA3400G Built-in...
My dishwasher is not working and is clogged. What can I do? It does not drain.
use a wet dry shop vac and attach it to the end of the drain hose to remove the water then you need to check the drain pump and make sure that there is nothing stopping it from turning
Jun 03, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Water will not pump out of dishwasher and fills up the kitchen sink. What could be causing this?
The problem Is you have a clog between the air-gap on the sink and where it attaches to the drain. If this is a new install and you have it hooked up to the garbage disposal you need to make sure you have knocked out the plug on the disposal.
As for it not pumping out the dishwasher that means the pump is clogged and needs to be cleaned out.
May 09, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have a hot point model hda3400g02bb it doesnt seem to drain is there a filter thats clogged or something like that or a pump?
Not your pump. At the back of the dishwasher you will see what looks like a screen. 4 screws hold this in. remove the screws and you will see right in the center a plunger assembly. Replace this because the small rubber cone is eaten away. Cost less than 20.00.
Jan 27, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Dishwasher Clogged
There is no filter on your dishwasher . If you are having a problem with it not draining than you will have to remove the drain line from the bottom of the pump.After doing this remove the hard line with a set of pliers. inside the hard line you find a diaphragm which is probably clogged up with rice or corn, remove debris and resemble. Before doing this try and remove most of the water by hand or a shop vac works best.
Jul 26, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Water won't drain
There is a drain hose for your dishwasher that often gets clogged. I would try this first. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. Go to google or youtube and type how to remove or install dishwasher hose or valve and you will find visual aids that way. Good luck
Jul 13, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint build in dishwasher will not drain hose not frozen or pl
hello sir you must have a clog at the drain valve or tubing where it enters sink connector alo makesure your drain tubing is not kink thanks from gilles
Jan 16, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
379 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
