Question about Home Security
Problem solving the dvr does not seem to allow any function use...no rewind  review,,,but it shows current on monitor....but I do not think it is currently recording...do these things fill up  and if so is it just simple to change? thanks for any help,,,of coarse I can not find the booklet...
    Problem Solver:
  • 14 Answers
Your DVr has a lock feature which is by mistake active. check this first
Posted on Jul 14, 2009
Intel foxnonn mother broad no diplay
Does it seem like it booted up all the way except the screen is blank? If so try the following.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 21, 2012 | Intel Foxconn Motherboard
Fn f1 diidnt do it, hdoes any one no if i can fix it wihout having to replave moniter or connection switch?
I think you are hitting the wrong Function Key combinations. Why are you using an external monitor anyway? What is wrong with the laptop's LCD Screen?
Plug in an external monitor and see if thedisplay shows up on it. It can be any kind of monitor even the old big fat crtmonitors as long as it has a vga cable to connect to your computer's vgaport. If so that proves your video card is ok. The video will showon most systems when you reboot without you having to do anything. Some systemswill require you to hit the FN (Function key) + F1 thru F12. Hold downthe FN key then hit the correct key for displaying on the monitor (F1 thruF12). The correct key will normally have CRT/LCD on it or it will havethe icon of a display.
Each time you press the FN key plus the correct Function Key it toggles the Display between three stages (Show on Laptop only, Show on External Monitor Only, Show on both the laptop and the external monitor).
Apr 09, 2012 | Computers & Internet
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Nikon d50 monitor does not work during photo shooting, must use view finder
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Apr 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Dish 510 DVR that wont record properly or play paused TV show
Make sure that the software is correct. Should be P4.07
you can go into the DVR and replace the hard drive but I would suggest getting Dish Home Plan, Replace the receiver and then cancel the Home Plan. Talk to Dish Network and they will work with you.
for tech support go to: tech.dishnetwork.com
Dec 27, 2009 | DISH Network DVR 510 DTV Receiver /...
Dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Rewind spring installation
You might be better off buying a new Pull start assembly. there not that expensive, unless your mower is so old they don't make it any more. under $20 dollars I think. unless its a Honda or something else ***. than maybe a little more expensive.             Jay..............
May 29, 2009 | Garden
Not able to play back on the DVR
The ssc duel records with a time signature that allows you to go back to a specific time to view the information on the harddrive. on the front of the dvr there are three buttons and the large round multi button. If you have the unit with vhs backup, then you just press the center small button on the front pannel and you'll get the menu that either allows you to select a time group to watch, or put in the time you want the playback to start. after you start the playback, then you can control the playback with the controls on the large multi function button. If your trying to play back the VHS tape, GOOD LUCK!!!!.....If you have the newer model without the vhs backup...then you have to press the stop button on the large multi function button...andthen press the center small button and then the other small button to the right...then you should be at the menu to play back the video either by selected time/date..or by half hour increments....good luck!!!
Dec 10, 2008 | Samsung SSC DVR Digital Video Recorder...
Can't record
id get some spliters and hook it up that way or call 888-553-1555 and up grade to a dvr where you can pause record and rewind live tv. or get the home media dvr where you can record 2 shows at one while watching a 3rd and record on the hmdvr and play that same show on up to 3 other tv's
Oct 29, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Home Security Logo
422 people viewed this question
Top Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
