Question about Singer Deluxe Knitting Machine
SINGER 700 - Knitting Machine - 2nd yarn does not knit or (patter
I have a knitting machine which does not knit the 2nd yarn in the "2" position. This is a Singer 700. I try the carriage from my Singer 360 and it does work perfectly. The arm is fine, and after many test I have concluded that it is the main carriage. I can do tuck with 1 yarn but no fairisle with 2 yarns. Thanks.
  • guindl Sep 26, 2009
    I found the solution to my problem!.. one of the lever under the carriage was completely jammed!..not moving! I took it all appart, clean it, put the spring back and it is now working!.
  • heidi rhiann May 11, 2010
    if you turn upside down your carriage and push the , tuck , slip faisle, etc buttons you should see a metal piece flip into a different position, it should also click, if you see no movement that will mean that either a sping as come off or snapped you will get to this from the top of the carriage by taking off the handle then the plastic covers then you should see the mechanism but you will need to be confident to try this bit, see how you feel about it you may wont to take it to the repair shop for the new springs... goodluck...nb that its not always a semetrical movement it will be 1 side then the other take a look at how the two work underneath side by side and compare..
  • 3 Answers
Not sure where you are located, but this may be a problem for a KM mechanic to fix.
If you are a bit handy with a screwdriver, you could turn the arm over ans see that the alignment for the yarn gate is determined by two phillips head screws near the magnets. There is a little bit of play as the screws go through slots not holes. If you loosen the screws and pull the yarn gate towards back of the plate this should place the yarn in the latch hooks of needles.
The other thing is that you should ensure that the brushes are set to the circle, not the weave position.
Posted on Sep 26, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: I'm feeling really stupid but I can't seem to feed
right now then just check you are not using too thicker yarn.. and that you have not got the tension disk too tight it may help you to loosen them off completely so you can then thread it through then tighten them to the required tension, also once you manage to thead it up never take the yarn out break it bear to the floor and tie a little knot with ends clipped close and just pull the new colour through it a good cheat! You should firstly lay the yarn in the place in needs to go between the two disks then pull down a little but more to the side it should be to the side away from the centre of the bed on which ever mast your threading up.. it should click and then run freely, hope this helps...Heidi
Posted on Mar 10, 2010
I am busy knitting baby booties. At one stage the patter says k2tog yrn. Dont know what that means.
k2tog yrn, means Knit two stiches together and put the Yarn Round Needle to create a new stich
Oct 14, 2017 | Sewing Machines
I am making half throw in the cable pattern also 2 cushions in aran wool how much wool would i need to buy
You deleted the last post as I was just about to post the answer!!
a set of aran knit cushion covers knitting pattern 99p ' to Knit ' Pinterest ...
https://www.pinterest.com/pin/353040058269560085/ Vintage Aran cushion cover set knitting pattern by knitcheap, £0.99 ... CUSHION FROM SQUARES - 250 grams of ARAN in Crafts, Knitting, Patterns ' eBay ... The possibilities for using sweaters for pillows are endless.... and would make great gifts! .... Many owl patterns on Ravelry, but don't have the seed stitch in the "body" ...
Double bed sized knitted throw - Knitting Paradise
www.knittingparadise.com/t-215627-1.html
  1. Cached
  2. Similar
I want to knit my nephew a double bed sized throw how many balls of double knitting wool 100grm balls of wool will I need please. ... im currently crocheting a large granny square bed over and currently am on ball 5 of 1000g aran wool just to ...
Knitting Calculator - LoveKnitting
www.loveknitting.com/knitting-calculators
  1. Cached
  2. Similar
The world's largest range of knitting yarn, patterns, needles, books and ... Circular · Single Point · Double Point · Interchangeable · Sets · For Children · Cable Needles · Crochet Hooks ... Convert between grams and ounces ... Roughly how much yarn will I need for a particular garment? ... Worsted, Aran, 10 ply, 4.5- 5.5 mm.
Estimating How Much Yarn to Buy - dummies
www.dummies.com/crafts/crocheting/estimating-how-much-yarn-to-buy/
  1. Cached
You need to know how much yarn to buy whenever you start a new knitting or crocheting project. You can figure out the yardage by using yarn calculations, ...
HOW MANY GRAMMS OF ARAN WOOL WOULD NEED TO KNIT TWO CUSHION COVERS Google...
Dec 27, 2016 | Sewing Machines
Can I get a manual for a Singer 322 Memo Matic knitting machine
You can probably order a copy by calling Singer at 800-474-6437.
Mar 21, 2010 | Singer Deluxe Knitting Machine
Knitting machine skipping stitches
hello , here are a few reasons why your machine may be skipping stitches. Possibly through to tighter tension either on the dial or on the masts at the top you will need to loosen them, possibly due to the yarn not feeding corectly, maybe it is that the yarn is snagging intermidtently on some thing, i take it you are using yarn off a cone specially for machine knitting.. maybe you have some sticky latches thats the bit that closes on the needles just check they should not stick or be twisted in any way if so change them, i do feel it is probably your tensions you need to look at first though i hope this helps but a few more details and i could help more thanks heidi
Dec 25, 2009 | Singer Deluxe Knitting Machine
Singer mod 700 knitting machine
I would google it thats the best thing and search.
Sep 15, 2009 | Singer Deluxe Knitting Machine
Hi there i am stuck im knitting a babys hooded coat and im stuck on the yoke ive knit the front back and sleeves and dont know how to put them together with the yoke can you help me pleas thanks
I believe you have do it by hand. A medium size crochet hook, with the same yarn used for the garment, do a looping chain stitch to attach the pieces.
Sep 14, 2009 | Singer Deluxe Knitting Machine
Singer Deluxe Knitting Machine Logo
744 people viewed this question
Top Singer Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Singer Toy Expert? Answer questions, earn points and help others
