Question about Tools & Hardware - Others
SN2 nailer will not nail,air comes out vent at
SN2 nailer will not nail,air comes out vent at head,but gun does not function
  • David Ford
    David Ford May 11, 2010
    How old is this tool and when was the last time it was serviced. It sounds like you have a bad oring or the firing valve is stuck. I would recommend looking at a breakdown and see if you are comfortable in performing the work. If you are handy it is not a big problem. Let me know what you want to do and I will find a schematic for you.
    New Friend:
  • 132 Answers
You will have to take it to a Senco approved repair facility. Sounds like the head seals or rings are shot. Dirt getting in the hose ends when you connnect and reconnect is a possiblity.
Posted on Jun 27, 2009
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
I have a senco sn2 nailer,the firing valve washer broke.\r\nwhat is the correct replacement part for this? will the same part that works on a sn325 fit the sn2? ive seen it listed on ebay saying it fits...
First make sure you have an SN2 or an SN2+,,,there are differences,,,go to senco.com and get the parts list and exploded view of the gun,,,,then go to juldan.com,,,they are the best of stocking most of the parts for obselete Senco tools!!
Apr 10, 2011 | Senco Air Tools & Compressors
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
My craftsman framing nailer has two nails jammed in head. Is this something I can repair myself?
Yes, just disconnect the air line and get in there and dig them nails out, don't wait for somebody else to work on it. Do it yourself. The front of that gun should lift up and expose the nails coming through, pull them out with pliers, make it clear, then reload and fire it back up and see what happens, a lot of times the generic nails will clog up.
Oct 10, 2010 | Nailers 3 12" Pneumatic Air Round Head...
When i push the trigger air is comming out but the gun is not shooting
make sure the safety release where the nail comes out is depressed. also check to see if it is low in nails/staples. I have an older nail gun that will stop when it is low on nails
Jan 13, 2010 | Grip Rite Grip - Rite 21 Round Head...
Gun stopped driving nails, air escapes from top,
has the gun been cleaned and oiled, i think not.
take the head bolts out of the top of the gun. make sure you pay attention to how everything comes out so you can put it back together.
shake the gun upside down so that the piston comes out. wipe everything down with any petroleum based cleaning solvent to remove all the gunk and reassemble.
pour about 10 dropsof oil down the air input, let it sit there about 5 mins and hook up the air and it should work
Sep 23, 2009 | Tools & Hardware - Others
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Air never stops coming out of gun nail,and gun doesn't sink nails
strip and clean the gun ,you will find that replaceing the seals will help no end
best of look ian
Mar 23, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Tools & Hardware - Others Logo
227 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
