Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
When my wireless router is connected via the socket on the front of the BT master socket , no internet connection is made but the telephones work. If I then take off the front plate of the master socket and connect the wireless router to the test socket inside the master socket, the internet connection is fine but of course no telephones work because the phone extension cables are connected to the socket in the front plate which has been removed.
I have tried switching all micro filters and disconnection all phones connected but the internet connection is impossible via the front plate connector socket.
  • 169 Answers
Every phone socket must have a working microfilter pluged as shown on the image below.
I think you need to change your microfilters as they might have blown.
BROADBAND INTERNET CONNECTION PROBLEM (WIRELESS) - microfilter2.gif&usg=afqjcnewmdhgecg08egxbhumf4zmq8g-lq
Hope this helps,
Abdul Qayyum
Posted on Jun 21, 2008
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Sky Broadband Wireless ADSL Sagem Router Errors with Screendumps
Generally speaking if your @ light on the front of your router is not lit then your telephone line is not enabled for ADSL however you will still be able to goto and check this is an example of the screen display
ERROR : Return Code 100
This also can happen if the twisted pair copper wire that is used to send the signal into your router has been disconnected or there is a short outside your house.
NOTE: That even if BT reconnect and complete a silent line test on your telephone line from your house from the Master Test socket behind your faceplate this doesn't mean that you will have a Broadband Signal from your ISP.
Under normal operation you should see the following screen click show statistics, this line is connected at 3.3MB
on Feb 08, 2010 | Linksys Wireless-G Broadband Router
Do i need bt wireless for on demand connection I only have bt broadband
You will need a wireless router, like the Apple Airport Express. It will connect to your broadband modem via an RJ45 (ethernet) cable.
Jun 25, 2014 | Computers & Internet
We have BT broadband. When we occasionally have to reset the router, everything except the 2 Dell Dimension 5150 desktops works via wireless. They refuse to reconnect. All the other Desktops / laptops work...
Not sure exactly what your hardware setup is, but I would reboot the broadband router, then reboot the wireless router. Everything should come up clean, but give it at least 5 min. To help connect after reboots, you can choose "repair" from the wireless icon in the system tray (XP?) or renew your IP address. Start --> Run... and type ipconfig /renew
Hope this helps!
If so, please leave a rating!
Mar 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
Xbox 360 connect to xbox live with out wirelless adaptor
wel your o2 router is basically ur internet so if that does not work i reccomend you switch to broadband and buy the wireless adaptor for the xbox 360 and use that if you dont no how to set that up send me an e-mail to and i will walk you through it step by step till ur up and running AND PLZ RATE THIS FOR I WILL NEED YOUR VOTE TO CONTINUE HELPING OTHERS WIT THE SAME PROBLEM YOU ARE HAVING TANKS.
Nov 26, 2008 | Microsoft Wireless Network Adapter Xbox...
How do i configure my Belkin router to work with Sky broadband?
I'm not into hacking what I cannot find on ISP's sites
From what I can gather from the Sky Broadband site reading the manual installation procedures -- the process is pretty much automatic when it comes to installing their equipment leaving no clues as to how they configure it. What is the model if the Belkin router? Options probably exist to attach your device to theirs either as a router (establishing a second network behind theirs) or an access point joining as a member of their network - meaning there would would be two wireless networks in either case in the house (as there are no indications I have found on the site that the provided the sky router can be configured in any way such as turning off wireless). At least according to the documentation the sky router's wireless is running WPA-PSK security / encryption which is good -- and the documentation for attaching non-sky wireless adapters appears to be documented here.
Sky Setup
Dec 15, 2007 | Computers & Internet
Computers & Internet Logo
179 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
