Question about Kenmore Washing Machines
The washer won't fill because the magnet fell out from the detergent drawer after being removed for cleaning. Where does the magnet go?
  • 15,935 Answers
On the right side - halfway down the try - you'll see the witness marks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Detergent drawer filled with water
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Mar 20, 2009 | Frigidaire Washing Machines
Frigidire front loader washer
The magnet goes on the front piece of the detergent tray. You must be getting a "DDO" (Detergent Drawer Open) error message. When you removed the detergent tray for cleaning, you probably also removed the white plastic (front) portion of the drawer from the darker plastic reservoir portion. That's when the magnet fell out. That magnet has to be in place for the washer to function properly.
It goes into the white plastic portion of the detergent tray. It is placed in the vertical position just inside the vertical wall of the front portion of the drawer on the right side (of the detergent tray) as you are looking at the washing machine. You really have to look for its' location, but with some effort you will see a vertical slot with "plastic retaining clips" which hold the magnet in place.
Hope you are successful but if not, post another problem citing details about what you have tried. I tried to post this message to you twice already, but the web site will not accept it for some reason. Perhaps they want you to purchase their "professional" (spelled expensive) service to resolve problems. We'll see.
Rascal
Feb 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Detergent drawer will not close and washer will not run.
pull draw out on right hand side fron you will see a little square recess,,,there a sensor on the in side of the main control,,if you cant seem to place take another magnet and place it on the side of control..and thats where to put the magnet
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Dec 28, 2008 | Kenmore 46462 Front Load Washer
Magnet
if it's a small rectangular magnet that appears, in our case, fell out, when you add detergent, softener, etc...the magnet goes on the right hand bottom corner of the drawer face, straight up and down, not sideways. this is evidently some type of sensor allowing the washer to start. we had an error code of "ddo" when the magnet fell out.
Sep 04, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
