Question about Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The drive belt broke belt when the pulley assembly and mounting screw came loose from the cabinet wall. I'm trying to find out how to run the belt around WHAT areas in order to fix this problem, and where does the pulley assembly fit on what wall of the cabinet - location-wise.
model # 87692100
part # 660997
  • 5,911 Answers
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Posted on Jun 25, 2009
How do I get to the igniter on my WP Gas Dryer (LGR8648PG)?
In order to get to the burner assembly where the igniter is located, you will need to open the dryer cabinet and remove the drum by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior.
6. Remove the dryer drum. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the belt from around the motor pulley. Then, with the belt still wrapped around the drum, use the belt to lift the entire drum out of the cabinet.
You can reference the following websites for helpful exploded view diagrams to assist you with assembling and disassembling your dryer:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Once you have completed your repairs, reassemble the dryer as follows:
1. Re-install the drum, making sure the rollers are seated properly in the groove around the perimeter in the rear. Make sure the belt is looped around the drum with the groove side facing the drum.
2. Have someone hold the drum in place while you re-install the belt over the tension pulley and motor. If working alone, kneel down so you can see the tensioner and motor and rest the drum front on your shoulder or knee.
NOTE: With the belt removed, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place.
3. Reinstall the belt tensioner by following these steps:
a. Loop the drive belt around the dryer drum with the groove side facing the drum.
b. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
c. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
NOTE: If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
4. Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier.
5. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Oct 07, 2010 | Whirlpool LGR8648PG Gas Dryer
How do I change a belt on a Kenmore 80 series model number 66812692?
Installing a new dryer belt for the dryer model you have listed involves the following steps:
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. A replacement pulley can be ordered on line at any of the following websites:
repairclinic.com
The part number is 691366 and is listed as item 39 under the "Cabinet" heading. NOTE: You can view helpful exploded view diagrams at searspartsdirect.com. Your model number should be entered as "110.66812692".
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Jan 12, 2010 | Dryers
Dryer drum will not turn. For a Kenmore 86810100. It sounds as if it is running, but the drum will not start.
This is usually caused by a broken dryer belt. To access and/or replace the belt on this model dryer follow these steps:
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
NOTE: The part number for a replacement belt is 341241. You can purchase the belt at appliancepartspros.com for about $10. If you do not wish to purchase on line, take the part number and go to your nearest appliance parts retailer. This is a common item they should have in their in-store inventory.
Nov 21, 2009 | Dishwashers
Kenmore Dryer Model 110.646.02300 Blower, heater run. Drum does not turn. How do I access belt?
Nov 03, 2009 | Kenmore 63942 Dryer
How do I instal the tension pulley and belt
If the model number you have this listed under is correct, replacing the dryer belt and installing the tensioner involves the following steps:
Oct 20, 2009 | Estate TEDX640JQ Electric Dryer
We need to replace the belt . It is broken and we are not sure exactly where it goes or if we have to take the dryer apart. Model number yleq5000kq1
The belt wraps around the dryer drum and connects to a pulley on the drive motor. It is held tightly in place by a belt tensioner.
Replacing the dryer belt and installing the tensioner on this model dryer involves the following steps:
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt and re-install the pulley, follow these steps:
Oct 14, 2009 | Dryers
How does is belt tensioner installed on estate dryer
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
Sep 24, 2009 | Estate TEDX640JQ Electric Dryer
I have a kenmore model#110.76662501 gas dryer. I
To access the dryer interior cabinet, follow these steps:
1. Unplug the dryer and turn off gas supply before servicing.
2. Remove the lint screen on the top of the dryer and locate the two screws under it.
3. Remove the two screws and the the top panel will lift up.
4. Disconnect the door switch connector plug and the ground wire (if installed). You may have to use a small flat blade screwdriver to unlock the tabs on the connector.
5. Locate the two mounting screws that hold the front panel to the two side panels. There should be one on each side of the dryer. Place your body against the front panel to keep the door closed and to support as you remove the screws.
6. With the front panel screws removed, grasp the entire front panel in the top center and lift straight up to remove.
You should be able to access the burner assembly now. You shouldn't have to remove the drum, but you can if it will give you better access. To do so, simply release the belt tension by taking the idler pulley and lifting up on the wheel. Remove the belt from the drive motor shaft and leave the belt wrapped around the drum. Using the belt as a handle, you can lift straight up and the entire drum will come out of the dryer.
NOTE: The idler pulley may come detached from the dryer cabinet floor when the belt tension is removed. This is normal.
Remember how the belt goes back in the dryer. If you forget you can re-install the belt and pulley by following these steps:
NOTE: To avoid any confusion, your Kenmore dryer is manufactured by Whirlpool. The "110" prefix in the model number identifies the manufacturer.
Aug 27, 2009 | Dryers
Replace dryer belt on 110.67832791
Replacing the dryer belt on this model dryer involves the following steps:
2. With the lint screen door open, remove the two screws and lift the top panel.
Aug 01, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
I need to replace the dryer belt
The belt on a dryer is inside the body, usually accessed and changed as follows
most base dryers
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
maytag
  • remove screws from bottom bend of front panel
  • lift front panel off
  • remove doo switch cable
  • sent front panel aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
Sep 06, 2008 | Dryers
Dryers Logo
1,099 people viewed this question
Top Dryers Experts
