Question about Home
I hooked up a new Delta faucet and when I turned the water back on even though the handle is off, the water won't shut off. What do you think could be the problem?
  • 68 Answers
Sediment in pipes man every time you shut off and turn on the wate rthe **** in the pipes gets stired up and messed up your new faucet. it happens im a plumber and one day put a new faucet in and when i turned the water back on same thing clogged with black sediment from the well. later did i find out they had a new pump put in the day before and were haeing problems with all the fixtures like shower vales and faucets luckily they owned up to it and it didnt come out of my pay check
Posted on Jun 27, 2009
I have water hammer on my new Peerless kitchen
Single lever faucets can turn off a water supply instantly. Try slowing down your handle motions when operating your faucet.
Water hammer can cause damage to your water supply system and attached equipment...namely...your water heater tank.
If your water piping is easily accessed....you can use pieces of carpet cut into 4 inch squares to isolate the pipe from the wood joists, then use a J hook or wire hook to secure the pipe and isolation material (carpet). If you have copper tubing be sure to use plastic coated J hooks or wire hooks. Good luck and always know how/where to turn your water off before working on your plumbing.
ps if the hammering becomes a continuous fluttering hammer when you slow your handle motion....you need to tighten your crown adjustment nut located under your handle....most new faucets come with a tool that has an Allen wrench on one side to tighten the handle hold down screw...and the opposite side will have a fork like tool that is specifically used to adjust the crown adjustment nut. The nut is usually white plastic and has two notches in the top that fit the fork like tool. Turn clockwise slightly...then test...repeat until fluttering hammer is gone.
Jun 30, 2014 | Delta Faucet Delta RP17453 Pull-Down...
Delta handle won't turn more than half way
Take the handle off and adjust the hot temperature stop. Its just a plastic piece that needs to be adjusted up more. It just fits in grooves like a gear. Its easy to do.
Apr 19, 2013 | Delta & Single Handle Shower Faucet
The cold water on my Delta double hand faucet is leaking. I replaced the spring and rubber seat. when I put it back together, i can not turn the water off with the handle. I took the stem assembly out...
I believe they go in one way ,, but I've seen some that are 180 degrees out, which would make it so the water won't shut off, also with delta and moen,, add some plumbers grease to the o rings and faucet washers, so they don't stick when replacing,
Sep 28, 2011 | Delta & Stem Unit Assembly
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Went to change the handle in my shower when putting it back together it wont shut off water runs even while turned off.
try taking handle off and shut off water from stem..nall inside body may have turned>>once off install handle at point where it goes in
Nov 22, 2010 | Delta Plumbing
My Delta type kitchen sink handle is loose and keeps shutting water off. I have to turn it up a lot to keep it going. I could remove Red / Blue plug and do not know what to do beyond to tighten it?
Inside the handle of a Delta kitchen sink faucet is a small setscrew. You need an 1/8th inch allean wrench or Delta faucet tool to lossen the setscrew. Rotat the screw about 3 full turns counterclockwise, this should be emough to remove the hnalde. Under the Delta faucet handle is a white plastic ring with four notches. If you have a Delta faucet tool, you place it in two of the notches and slowly turn the ring clockwise to tighten the Delta ball assemby. This will keep the handle from moving by itself. If you do not have Delta faucet tool, use a pair of needle nose pliers in stead.
Oct 12, 2010 | Plumbing
My Delta Model 174 sputters air when turned on and leaks from the base of the spout. What causes this?
Air is getting into your water line, though I can't imagine how since it's a closed system. The only time this might occur is if the water main was shut off and all the water was drained from the lines. This is only necessary if your doing some plumbing work.
Jan 26, 2010 | Delta Faucet Delta 174-SSWF Waterfall...
We have a very old Delta & Single Handle Shower Faucet. The screw in the handle is now stripped since it was so rusted. How can we get the plastic knob off???
you can try drilling a small pilot hole and then use an "easy out" (get'em at any hardware store). or take some large pliers and break the plastic handle and remove the whole cartridge. Go get a new cartridge and handle. Make sure main water valve is shut-off prior do doing so though.
Jan 17, 2010 | Delta & Single Handle Shower Faucet
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Home Logo
201 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
