Question about Sun E2900 Server (E294P16GB1200)
Sun.serengeti.CommException: CBH Port is disabled in Sun F E2900
Sun.serengeti.CommException: CBH Port is disabled: RP0.ar.50 (13480050) system not getting booted
System getting in hung state quite often have to manually poweroff & poweron
2 Suggested Answers
  • 13433 Answers
SOURCE: Am getting the following error
You are getting a hardware failure notification, which was caused by trying to get the temperature of a processor. The cpu board has a problem.
thats as much as I can translate from the error message.
With all due respect, with a 12K - 20k or how ever much it cost you, you can afford to get a professional repairer or contact sun directly, you are at a user to user helpsite, the cheapest possible support.
It is so extremely unlikely that you would find someone with direct experience with this machine from this website.
Posted on Nov 10, 2010
My spy sun glasses displays rainbow colours when played
Polarized Sunglassessunglasses.lovetoknow.com > ... > Sunglasses > Types of SunglassesCached - SimilarShareShared on Google+. View the post.You +1'd this publicly. UndoHow polarized sunglasses are made • What colors are available? ... Polycarbonate lenses are created in a different manner, since polycarbonate lenses ... display appears black when you look at it through your polarized sunglasses, tilt your ... Acies, Anarchy, Bolle, Kaenon, Maui Jim, Oakley, Ray-Ban, Serengeti, and Spy.
Nov 26, 2012 | Televison & Video
System Mechanic 10 hangs
In the future you might want to get CCleaner instead. It's much better and totally FREE and does most of the same tasks as System mechanic. You can get it here:
http://majorgeeks.com/download.php?det=5125
Check out the other FREE useful app they make here:
http://www.piriform.com/products
Aug 18, 2012 | IOLO System Mechanic Premium Full Version...
0x8007045d error the request could not be preformed because of an I/O device error
I'd suggest you to connect your external hard drive to a different USB port and try copying and check if that fixes the issue.
Also, boot into safe mode and try copying the same and check if you can successfully complete the copy operation without any errors.
Refer the below link for more details on how to start computer in safe mode:
Start your computer in safe mode
http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
If you're able to successfully copy the file in safe mode, it indicates that one of the third party application or start up item is causing the error.
You could put your system in clean boot state and check if any third party application or any services is causing the issue and hence the error.
Putting your system in clean boot state helps in identifying if any third party applications or startup items are causing the issue. If yes, you may go ahead and disable or uninstall the same.
Follow the below steps to put your computer in clean boot state:
1. Log on to the computer by using an account that has administrator rights.
2. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
3. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
4. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
5. Click OK, and then click Restart.
Once the system is in clean boot state, try to copy the files and check if you're able to copy files without any errors.
Refer the link below for more details:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
After you have finished troubleshooting, follow these steps to reset the computer to start as usual:
1. Click Start, type msconfig.exe in the Start Search box, and then press ENTER. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
2. On the General tab, click the Normal Startup option, and then click OK.
3. When you are prompted to restart the computer, click Restart.
Jun 25, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
How to communicate or activate my gprs?
hello beljohn,
i have some tips for your question hope this helps
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
Apr 14, 2011 | Nokia C3 Cell Phone
How to activate the gprs of nokia 1616
it depends on your carrier for Sun Cellular
Setup/Enable GPRS
Select Sun GPRS
APN: "wap"
Select SUN MMS
APN: "mms"
Setup/Enable MMS
Proxy Port: "8080"
Setup/Enable WAP
Proxy Port: "8080"
Mar 07, 2011 | GPS
What is the gprs settings for china phone 9000c blackberry clone for globe provider?
bought a similar unit yesterday blackberry 9000c and Im quite lucky to be able to successfully configure its gprs settings for globe and sun.
You may try this out:
Smart 3G/Internet
  • Connection name: Smart Internet
  • Access point name: internet
  • Username: blank
  • Password: blank
  • Proxy: blank
  • Proxy port: blank
  • Homepage: http://m.smart.com.ph
Smart GPRS
  • Connection name: Smart GPRS
  • Access point name: smart1
  • Username: blank
  • Password: blank
  • Proxy: 10.102.61.46
  • Proxy port: 8080
Smart MMS
  • Connection name: Smart MMS
  • Access point name: mms
  • Username: blank
  • Password: blank
  • MMSC: http://10.102.61.238:8002
  • MMS proxy: 10.102.61.46:8080
If you're too lazy to manually tinker with the settings, however, you could opt to text SET to 211 and follow the instructions. It'll cost you, though, and you'll need to key in a PIN (1234).
Once you've entered the values stated above, you'll need to activate them. To do this, simply text MMS ON and 3G ON to 333.
Sun 3G/Internet
  • Connection name: Sun INTERNET
  • Access point name: minternet
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: http://www.suncellular.com.ph
Sun GPRS
  • Connection name: Sun WAP GPRS
  • Access point name: wap
  • Username: blank
  • Password: blank
  • Proxy: 203.138.159.78
  • Proxy port: 8080
Sun MMS
  • Connection name: Sun MMS
  • Username: blank
  • Password: blank
  • MMSC: http://mmscenter.www.suncellular.com.ph
  • MMS proxy: 203.138.159.78
  • Proxy port: 8080
Globe 3G/Internet
  • Connection name: MyGlobe INTERNET
  • Access point name: internet.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: enabled
  • Proxy port: 0
  • Homepage: www.globe.com.ph/globe.asp
Globe GPRS
  • Connection name: MyGlobe GPRS
  • Access point name: www.globe.com.ph
  • Username: blank
  • Password: blank
  • Proxy: 203.177.042.214
  • Proxy port: 8080
  • Homepage: http://www.globe.com.ph/globe.asp
Globe MMS
  • Connection name: myGlobe MMS
  • Access point name: mms.globe.com.ph
  • Username: blank
  • Password: blank
  • MMSC: http://192.40.100.22:10021/mmsc
  • MMS proxy: 203.177.042.214
hope this info helps.
Jan 16, 2011 | Cell Phones
Little man icon lit up as well as the sun like button
like the sun light means that change developer
May 25, 2010 | Sharp AR-M205 Copier
WHEN TURNED ON THE SCREEN IS BLACK BUT THE MOUSE IS STILL THERE AND IS ABLE TO MOVE? WHAT'S GOING ON?
Windows is having issues booting and gets hung up. Try to reinstall Windows.
Oct 20, 2009 | Computers & Internet
Drivers side sun visor hanging loose in my way all the time
2006-2007MY SONATA SUN VISOR
REPLACEMENT (SERVICE CAMPAIGN T64)
CAMPAIGN APPLIES TO VEHICLES LOCATED IN THE WESTERN,
PC, AND SOUTHERN REGIONS ONLY. THIS WOULD INCLUDE
THE STATES AL, AR, AZ, CA, CO, FL, GA, HI, KS, LA, MS, NC, NM,
NV, OK, OR, SC, TN, TX UT, AND WA.
Aug 24, 2009 | 2006 Hyundai Sonata
Sun E2900 Server (E294P16GB1200) Logo
193 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
