Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The cable broke which engages my blades on my craftsman 17 .5 hp 42 inch. I need a model part number for the same . I have lost my owners manual with that information
  • Dwain Pippen May 11, 2010
    You should still have the model number on a sticker under the seat. With that number I can look up the part you need.
  • 284 Answers
Locate mod # on tractor may be under seat
go to sears.com click on parts direct and enter that number and it will take you to the parts section for that mower.
Posted on Jun 26, 2009
A cable is loose that will not allow me to engage the blades, how do I reattach the cable. it is a craftsman Lt 1000 17 IC ohv . model # 917.272260 42 inch cut.
Tightening up a stretched cable is impossible. If the cable is NOT adjustable to shorten it and make it tighter, then you will need a new one. Here is a link to one. I searched all the parts diagrams in your manual for the cable and find it was NOT listed. I hope this helps as I have researched your problem. Go here:
http://amcpartsstore.com/FSP-Deck-Blade-Engage-Cable-Craftsman/M/B0014G6T1S.htm
Aug 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The mower deck clutch cable broke so blades will not engage and lever is loose on my Sears Craftsman 42-inch lawn tractor (917-271-742). I fished out the top piece of the cable, about 12 inches down to a...
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Jun 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My craftsman model 917272681 lawn tractor will not engage the blade and I cannot find my english manual but have looked at picture in spanish manual and cannot figure out what is problem. help
Go to searsparts.com type in your model number,may need belt is belt on deck if so could be your engagement cable broke If you need one I may be able to help you find it.
May 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
491 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
