Question about Saeco Odea Giro Plus Coffee Maker
Machine stoppped working
My saeco odea giro worked for 2 weeks and it no longer brews. The alarm light is permanently on. It will not prime. I have tried cleaning all parts, descaling, everything. When i follow the instructions to prime it, no water comes out and the spout is not clogged. What should I try next?
  • 1 more comment
  • ces3 Jun 27, 2009
    No. It does not make any sound. Thank you for your response.
  • ces3 Jun 30, 2009
    I will try this and let you know how it works. Although the machine was used for approximately 2 weeks it was purchased about 6 months prior. It stayed in the box until we were finished remodeling. Thank you for your help.
  • Ernest R
    Ernest R May 11, 2010
    Does the pump make any sound when you try to prime?
    President:
  • 1,618 Answers
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Posted on Jun 30, 2009
  • Ernest R
    Ernest R Jun 30, 2009
    The warning light on usualy means that the brew unit, dregs tray or water tank needs attention or is not inserted properly.
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I...
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
Apr 29, 2017 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro Plus spare parts needed
The coffee dispensing valve is available at your saeco dealer 1-2 hr job to change...
Sep 27, 2009 | Saeco Odea Giro Plus Coffee Maker
Seaco Giro Quick Flashing Red Alarm
Bypass the door interlock with a magnet (the red light will go out when you have the magnet correctly placed above the group). Brew a cup and watch to see how the water is getting into the hopper. Once you know how it is getting into the hopper it should be relatively easy to determine how to fix it.
Apr 21, 2009 | Saeco Odea Giro Plus Coffee Maker
Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
May 26, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Odea Giro Plus Coffee Maker Logo
1,184 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
