Question about Thetford Norcold RV Cooler/Freezer
Why does amana frostfree refrigerator ice up when you overload the freezer?
    New Friend:
Sounds like the airflow is being block by the overload of product. No air flow means a frozen coil.
Posted on Jun 10, 2014
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Ice has formed in the freezer of my electrolux frostfree refrigerator & the lower compartments are not cooling. what do I do now?
Could be door has been accidently left open and now ice is blocking the air flow, try switching it off for at least 12 hours with door open to manually defrost ice. Also check that the fan inside the freezer is running.
Nov 02, 2010 | Electrolux Refrigerators
Amana AFD2535DEW - Freezer compartment is operating fine, but refrigerator compartment is not getting any cold air, even though both compartments are set at "4". The baffel is open were the cold air would...
either the evaporator coil behind the freezer compartment wall is iced over and you can';t move cold air over an iced up evaporator coil to cool the refrigerator compartment or the compressor relay/overload is bad
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Amana ABC2037DEB after 4 years, now freezer click and hum melting
that click followed by a hum can only be one thing
pull the unit out and feel the compressor, if its really hot you have a relay and overload issue, and it struggles to start.
with any luck, it is the external relay and overload found mounted to the comresssor should be a lil white block
if not it will be two differant parts
a lil white one and a brown one
let these cool a bit and check both for continutity
ive included a link for the parts
they are 10 and 11 on the schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174380&diagram_id=1358665#d1358665
Oct 22, 2009 | Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ...
Ice pooling in bottom of frostfree freezer
Sounds like the drain tube(s) which carry the defrost water from the freezer and refrigerator to a catch pan at the bottom of the refrigerator are stopped up.
I have seen these drainage tubes stopped up with debris which prevented the water from draining out. This defrost water can be turned into ice which blocks the defrost drainage even more so.
Oct 09, 2009 | Refrigerators
Amana BX21VW cool but not cold, compressor not working
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 13, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Ice repeatedly forms at the bottom of the freezer compartment. Eventually it reaches the door and water leaks out. Signature Series Frostfree Model HMG51108
Your defrost drain line is frozen up.
Turn off fridge, remove bottom freezer drawers.
Remove visible ice.
Take a hair dryer and melt ice at the back of the freezer at the drain pan.
Pour a water and bleach mixture through drain hole.
This procedure could take a hour or more.
Feb 21, 2009 | Admiral 26 cu. ft. Side-By-Side...
Thetford Norcold RV Cooler/Freezer Logo
Top Thetford Refrigerators Experts
John Tripp
John Tripp
tom wright
tom wright
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
