Question about Samsung DLP HL-P5663W 56" TV
I also have diagonal lines running through picture. However, when
Using pip, the second picture is perfectly clear.
  • 6,784 Answers
HI, the PIP runs through a separate stream and, is separate from the main. these lines are being produced by a failing DMD or, Light engine. You will need to replace this failing board soon. it is failing slowly.
Posted on Jun 25, 2009
Cable input
Hi
I think the problem is in the tuner, a small metal box near the antenna input and can be removed and serviced. But first you should check the DC supply line to the tuner. The circuit has a big limiting resistor (15K/3W) and a 33V zener diode and a small filter electrolitic capacitor). The zener is prone to be leaky and unstable.
Sully
Sep 27, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Diagonal lines through the picture of Samsung DLP set.
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Dec 27, 2008 | Samsung HLN5065W 50" Rear Projection...
Hi
where the line is coming out? from left to right of your screen or bottom to top?
Thanks!
Dec 27, 2008 | Televison & Video
Faint diagonal lines on main screen but not PIP mode
Shielded digital board is located in the center looking in the back mounted vertically. Slightly heating center with a blow dryer may cause the picture to clear temporarily. There are three 10uf/16v caps that generally go bad in the center lower area of this board C655, C638 and C714, their ESR will generally be very high when cold. You can either replace these caps or replace the board. Caps are an inexpensive but a difficult repair the board is about $350 plus core part #Bp94-00385a and available at places like Vance Baldwin.
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 28, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Scrolling faint diagonal lines
IS NOT CLEAR IF YOU ARE USING CABLE BOX OR THE TV TUNER . BUT IF ITS THE TV TUNER IN USE WHEN THIS HAPPENS , MORE LIKELY TO BE A BAD ANTENNA CABLE CONNECTOR
May 08, 2008 | Vizio L32 32 in. LCD HDTV
Screen lines on MacBook.
Sounds like dropped pixels.  My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
Mar 19, 2008 | Apple MacBook PC Notebook
Green Screen
It can be a result of dry solder joints on the CRT base PCB, the PCB you see on the end of the CRT. Resolder all the joints on that board perfectly and thouroughly and this will be alright. Good luck.
Jan 14, 2008 | Samsung TXN3245FP 32" TV
Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Dec 20, 2007 | Gateway LCD30TV Television
Samsung DLP HL-P5663W 56" TV Logo
308 people viewed this question
Jerry Greenberg
Jerry Greenberg
