Question about Clarion DXZ945MP CD Player
Wiring confusion I cant stand a quiet ride, I took my radio out only to find that the prior owner did not use a harness.My new radio Since i already started i finished but not quite. I dont know which wire goes to which.I am installing a Clarion DXZ945MP unit. Heres the diagram for my car: 1994 Honda Civic Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Blue/White Car Radio Switched 12V+ Wire: Yellow/Red Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Radio Dimmer Wire: N/A Car Radio Power Antenna Trigger Wire: N/A Car Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/Green Left Front Speaker Wire (-): Gray/Black Right Front Speaker Wire (+): Red/Green Right Front Speaker Wire (-): Brown/Black Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Blue/Yellow Left Rear Speaker Wire (-): Gray/White Right Rear Speaker Wire (+): Red/Yellow Right Rear Speaker Wire (-): Brown/White Please help if you can.
  • dfisher8582 Jun 26, 2009
    ok i will try that thanks
  • Anonymous Mar 13, 2014
    I try to change the original radio in 1994 to Aiwa car stereo, nut I put the wire red with red, yellow with yellow and black with black and don't turn on, what I missing.
  • 578 Answers
Yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
Craftsman 944601090 seat safety switch problems
You should only need two of the three wires remaining. I also can't find your model number anywhere. Did you post the model number correctly?
Jul 15, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cant find a harness to plug into the back of a Dual XD250 RADIO.
You won't ever. They make a universal harness. You should have a wire harness for your new radio only that was included with the radio. It should plug into the new radio and the other end will just be wires. Then you will need to go to a parts store, ( AutoZone, Oreilly's, Advance Auto, Etc) and but a radio wire harness for your truck. It will have a connector or two that plug into the harness that plugs into the back of your stock radio and the other end will be just wires. you will then connect the two harnesses together by matching wire color. ( EG: Purple to Purple, Gray with black stripe to Gray with black stripe, etc)
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Car Audio & Video
I cant get sound out of my speakers. i put in a new stereo and hooked it up
Did you use a wire harness specific to your vehicle year and model? Make sure you get the right harness, depending on what factory system came with the car(base or mach460 sound systems), If your speakers were working prior to replacing the radio, then there's a possibility that the harness may not be compatible. also, the car may be equipped with a factory amp(mach460 systems). Here's a link that may help you figure it out. http://www.modifiedlife.com/2000-ford-mustang-car-stereo-wiring-instructions/
Sep 23, 2011 | 2000 Ford Mustang
I have brought a second hand unit and was wondering if I can order the wiring harness from anywhere or make one???
So you purchased another radio, right? Then it came with the harness already(for the radio and not the car). If the current radio is the factory radio then you need to purchase a wiring harness for the model/year of your car that will be compatible with your car's harness. Wal mart carries some but if you can't find it there then you need to go to your local car audio installation shop and buy one from them(it might be pricey there). Now, if your current radio is aftermarket, look to see if it already has the wire harness in the back. If it does then your good to go, just cut the harness from the radio away from the harness that plugs to the car's wire harness and reconnect using your new radio's harness(just follow the wire's color code). but if it doesn't then you need to buy one.
Jul 06, 2011 | Car Audio & Video
Purchased and installing an oem radio and there is a fuse in the radio slot that is red and about half the size of the other fuses. It say it is a 10 amp fuse, looks fine, but the radio does not power up....
Be there a few times!! Depending on what vehicle you have...sometimes if you search online you can find the radio wiring harness (colour coded). If its a new ride, then it shouldn't be hard! With an old ride, what happens is a lot of owners install a radio, then remove it, on and on they go, till the wires get shorter.....then some people start adding new wire....but they never match the colour up! What i would suggest is buy a voltage tester and test all the wires till you find power! (won"t necessarily be red). Once u find power...your golden there! Then you wanna look for ignition....which will only show power with the key ahead! Always be careful,if your not familiar or comfortable doing this, seek a professional! hope that helps!
Nov 25, 2010 | 1987 Dodge Dakota
Nsr 125 problem
It may be a safety switch in the clutch lever or bike stand switch being a bit sticky or broken wire in the wiring harness near the steering head that bends alot.
Apr 25, 2010 | 2000 Honda NSR 125
Nissan Almera Tino 2004 - built-in radio is quiet or screeches
with the proper wire harness you can retrofit any aftermarket indash you want call any car audio shop they will be happy to set you up with exactly what you need
Mar 10, 2010 | Car Audio & Video
Cant find the plugs for the wiring harness for the cd player
Radio wiring will start from the fuse box side to the back of the radio. Speaker wiring will be packed away with other related interior wiring
May 24, 2009 | 1992 Buick Regal
Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Feb 22, 2009 | Dual XDMR7710 CD Player
Clarion DXZ945MP CD Player Logo
597 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
