Question about Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 -ABC LIGHTS LIT UP IN BACK USB-HIGH FAN SPEED
Computer won't boot, orange lights are lit at the usb ports. beeps a bunch when power is re-supplied. There has been a real high fan speed when doing large AutoCAD drawings until now. Will not boot at all just beeps and lights. Any suggestions?
Thanks
  • juanitodjmx Nov 25, 2009
    HI!
    I don't speak english, but I understand more or less
    I have Dell optiplex 280
    My problem is this:
    A,B,C YELLOW AND D GREEN.
    Diagnostic Lights
    Problem Description: A possible BIOS
    failure has occurred; the computer is in the
    recovery mode.
    Suggested Resolution:
    Run the BIOS Recovery utility, wait for
    recovery completion, and then restart the
    computer.
    QUESTION FOR YOU!!
    HOW TO RUN Run the BIOS Recovery utility? AND
    Where can I download the Recovery utility for my dell optiplex 280?
    Thanks!
System halted my pc help
Posted on Feb 25, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 194 Answers
A possible BIOS failure has occurred; the computer is in the recovery mode
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
where as the solid orange light says
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
Posted on Jun 25, 2009
  • Dell Master
  • 1,684 Answers
High fan speed indicates the system is overheating and the motherboard is speeding up the fans trying to keep cool. You problem now sounds like either the power supply or the motherboard was damaged because of the heat. The GX270 and GX280 system are plagued with this problem. The fan in the power supply goes out or does not spin fast enough to cool the system. When this happens parts called capacitors over heat and can pop. Go to my web site at :
www.ccl-la.com/badcaps.htm
Look at the pictures and open your computer case and check your motherboard. If you see any capacitors that look like the one on my site then your board will need to be repaired or replaced. The bottom 2 pictures are from the Dell GX270 and GX280 motherboards. Also while you have your case open try to power up your computer and see if the power supply fan spins, if it does not spin then you will need to replace it.
I hope this helps,
Buddy
Corporate Computer
www.ccl-la.com
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Keyboard & Mouse not inputting..Dell OptiPlex GX280.. OS, XP. Microsoft Wireless Desktop 3000 (keyboard/mouse) new.. Dell boots up and desktop appears, the cursor (arrow head) remains in middle of...
Check that batteries are charged and installed properly.--make sure driver disc is installed if applicable- check instructions as some wireless suites need you to push a small connect button to initialise them . Also try shifting the usb conector into another USB port if it is notm getting reconised.
I hope this helps
Andrew.A
Apr 09, 2011 | Dell OptiPlex GX280 PC Desktop
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 30, 2009 | Dell Computers & Internet
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell optiplex gx280 multi key pressing problem?
dear sir
yes her then running versons don't have any ps2 port's avalable but don't worry u have usb port but u need to perchase 1 convater called " USB to PS2" it's maky yr usb port to 1ps2 keyboard and 1 ps2 mouse prot.. it's help U...:0
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | Dell OptiPlex GX280 PC Desktop
Dell GX280
Same problem... orange power light, fan starts slow and builds up to very high speed.
I removed my video card and SIMMs --> it beeped on boot and the fan did not speed up.
Put one SIMM back in --> booted fine, pressed F2 to view BIOS. Memory reported fine.
Put all SIMMs back in --> all fine now.
Dec 01, 2008 | Dell OptiPlex GX280 PC Desktop
Can't load os do you computer Dell only has usb ports
Ensure the Keyboard and mouse are connected to the USB ports nearest the PS2 port on the back of the chassis.
Boot to the BIOS F2 and ensure USB emulation is ON.
If you can't access the bios, reset the BIOS using the Jumper on the motherboard, then USB ports should then work.
May 18, 2008 | Dell OptiPlex GX280 PC Desktop
Motherboard issues
YOU MUST SEND THAT UR PC GIVES HOW MANY BEEPS? THEN I TRY TO SOLVE.
Dec 13, 2007 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
2,680 people viewed this question
Alun Cox
